928 Forum 1978-1995
Sponsored by: 928 Specialists
I bought my first Porsche 928 - Nightmare!
Old 03-04-2014 | 04:57 PM
  #76
The Fixer's Avatar
The Fixer
[QUOTE=James Bailey;11185685]
Originally Posted by The Fixer
BEFORE he buys a $1,500 radiator it would be good to KNOW the engine is O K ....the 1980-1984 USA cars never ran the heat exchangers for the engine oil so unless you are really using the 300 HP a lot the car can live quite well without it.
I get that Mr Bailey, i commented that 'looping' lines should not be necessary to run the motor.
Plugging the block ports is easier and safer imho to test,
and fine to leave if he wants to run it without the cooler.
Sorry for the confusion, as you all were..
Old 03-04-2014 | 05:08 PM
  #77
wg928's Avatar
wg928
we know where to find ricster....he too will get sorted
maybe he had lunch with fonetico
Old 03-04-2014 | 10:09 PM
  #78
Dave928S's Avatar
Dave928S
You need to put a loop in to take the place of the low resistance path of the cooler. When the motor is cold the thermostat is open and sends the oil straight to the filter and then to the oil galleries ... above 87 degrees C the thermostat is closed and sends the oil to the cooler, before it runs to the filter and galleries. If you plug the ports to the cooler it will mean that you block flow altogether (via the t/stat) when the oil temp rises and the t/stat closes. With that path blocked altogether when the oil has risen to operating temp, the only path for the oil to get past the closed t/stat and plugged ports, is via the bypass valve which opens when there's a pressure differential of 0.5 to 1.0 bar ... and you then have total reliance on that bypass valve to open and not limit the flow.
Fit a loop and you have a low loss path to replace the cooler ... and still have the back up of the bypass valve opening if there's any restriction.
Edit: If you wanted to run the car permanently without a cooler/radiator heat exchanger you could plug those ports, but you'd need to remove the oil thermostat or oil bypass valve .. or both ... to ensure you had a fail safe path for oil flow to the filter.
Old 03-04-2014 | 10:41 PM
  #79
hacker-pschorr's Avatar
hacker-pschorr
Administrator - "Tyson"
Originally Posted by ricster
Get a 911 a much better reliabilty
Old 03-05-2014 | 01:11 AM
  #80
The Fixer's Avatar
The Fixer
[QUOTE=Dave928S;11186548]
Great detail to include Dave,
remove the oil thermostat if you plan to plug the cooler ports and run without a cooler and don't want a loop.
Ports are located just above the oil pressure sender (59) with regulating device which are #s 54,55,56
Very simple to do.
Old 03-05-2014 | 01:41 AM
  #81
Hilton's Avatar
Hilton
Sheesh the last few posts are confusing.
You need to make sure there's a /QUOTE tag to go with each quote
Old 03-05-2014 | 02:33 AM
  #82
Fogey1's Avatar
Fogey1
Originally Posted by FredR
Very sorry to read of your experience- seems "the luck of the Irish" does not always hold true.
Originally Posted by Fogey1
Nobody said "the luck of the Irish" was always good, especially when dealing with their neighbors from the east.
P.S. Good Luck. And if you end up stuck with the car don't give up - consider what Glyn says above.
Originally Posted by Maybach_Man
And the relevance of this comment to the thread is??????????????????????????
Relevance? Well ...
First, I was replying to and commenting on a previous post. I admit I was snarky in the first sentence - but the OP _had_ bought a car from another country, a country with which his country famously has a long and sometimes unhappy history.
Second, I was encouraging the OP not to give up.
Sorry if I touched a nerve while squandering bandwidth. I was trying for a wry chuckle.
Old 03-05-2014 | 02:53 AM
  #83
Dave928S's Avatar
Dave928S
Oops perpetuated the error from #72 .. fixed mine .. am I forgiven? ..
Old 03-05-2014 | 03:55 AM
  #84
Hilton's Avatar
Hilton
Not yet my son. Go drive 15km and say 3 "hell yeah"s.
Old 05-05-2014 | 12:10 PM
  #85
major dad's Avatar
major dad
Wonder how this ended up? It's a small world, I 'm also from Cork and bought a 928 GT in April 2014.
Quick Reply: I bought my first Porsche 928 - Nightmare!
