Seeking Alarm Info (was seeking ABS info)
Electron Wrangler
I am seeking information about the ABS relays mounted on the hydraulic unit - these are Bosch relays with the round pins - at least thats how they look on the late models.
ABS was available as an option from 1984 - 1990 (M593) from 1991 on it was standard.
The relays mounted on the ABS Hydraulic unit from '89-95 are the same:
Activation Relay: 0.332.002.173 (7 pin) Bosch
Pump Relay: 0.332.002.171 (4 pin) Bosch
Earlier cars from 1984 appear to me to use the same pump relay
Pump Relay: 0.332.002.171 (4 pin) Bosch (but I can't be sure...?)
These same cars for sure use a different activation relay
Activation Relay: ?.???.???.??? (5 pin) I cannot find this ID? - nor ANY 5 pin, round pin Bosch ABS relays
Anyone have data on this?
Alan
Alan
Basic Sponsor
Relays on the ABS unit ---
84 to 87 = 928 618 931 00 = Bosch #0332205003 (5 pin)
88 = 928 618 931 01
89 to 95 = 928 618 931 02= Bosch #0332002173 (7 pin)
84 to 87 = 928 618 930 00 - Bosch #0332002176 (4 pin)
88 to 95 = 928 618 930 01 = Bosch #0332002171 (4 pin)
All stand alone relays and they do not SS. Do not know the other Bosch numbers
88 = 928 618 931 01
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Electron Wrangler
Alan
Electron Wrangler
88 = 928 618 931 01
88 = 928 618 931 01
For those following along this is part of the "Relays not Located on the CE Panel" documentation - working my way through that now - the ABS unit relays on the hydraulic unit were never very well documented elsewhere - now they will be - with major help from Roger!
Alan
Basic Sponsor
I think you mean 964 615 135 00 which SS to 964 615 135 01.
I am pretty sure it is available but can double check tomorrow.
You must be going bats with all these numbers - I have to double check myself.
Electron Wrangler
Ahh I typed it wrong - yes 964 615 135 00 I have it written here correctly from a old photo of mine.
No wonder I didn't find any... you get dyslexic eventually...
Alan
Alan
Basic Sponsor
Alan - when I counted the round pins on the relays I only counted metal pins. Each relay had a plastic guide post/pin as well.
Roger
Roger
Electron Wrangler
Electron Wrangler
OK quest has moved on - Now looking at alarms:
There are various alarm modules over the years (they are really just single/double/triple/quad smart relays) - here's what I think... where am I wrong?
Main Alarm Unit:
1978 - 1982 - 928.618.117.00 (behind glovebox?)
1983 - 1986 - 928.637.104.00 (behind glovebox?)
1987 - 1990 - 928.637.104.05 (behind glovebox?)
1991 - 928.618.260.00 (beneath RHS seat)
1992 - 1995 - 928.618.260.01 (beneath RHS seat)
Secondary Alarm Unit:
1989-1990 only 928.637.160.00 - In console
Alarm Foglight Flasher:
1988 - 1990 only 944.615.113.00/01 - In console
Roger can you help?
Alan
Main Alarm Unit:
Roger can you help?
Alan
