Completely stumped- horns
I know that I'm missing something really obvious here, but I've checked a few items on my inoperative horns, and it all checks-out...but no horns.
I have an aftermarket MOMO wheel and their horn button. It works perfectly and closes the circuit when I test for continuity.
I have 12 volts at the 2 wires fitted to the horn button.
When I press the button, I get 12 volts at the wires affixed to the horns.
I've applied 12 volts to the horns and they both work.
But they will not blow. What am I missing?? I'm stumped....
Bob
Bob
Team Owner
test the other way ,
go from the tab on the TS switch to the steering shaft,
if you have a horn then put on the steering wheel,
make sure to adjust the TS switch so the tab is just making contact with the horn ring,
view the switch height from under the column.
then touch the wire to the steering shaft if good then test the horn button metal spring to shaft.
NOTE If the upper column bearing is loose it can cause the ground to be broken.
NOTE if the button has 2 wires then they must be wired correctly. this may be your issue
Chronic Tool Dropper
I started with the ohm meter plugged into the relay socket. Worked backwards through the horn button side to verify that I had continuity to ground at the 31 socket terminal when the button is pressed. Going the other way, I could verify that I could toot the horns from the relay socket with a jumper from 30 to 87. You need to show 12V at 30 in the socket, as well as at the 86 terminal in the socket. referenced to ground.
Really helpful. Never thought about the relay.
Again, my 'stumped' comment was based on seeing 12V at my meter attached to the horn connections. If I have 12V there, why will a pair of working horns not blow? Overlooked the ability to jump at the relay and test them.
Thanks!
Thanks!
Electron Wrangler
I'll bet you don't have 12v there when the horn is actually connected... The horn is a high current device - if you have poor circuit connectivity (resistance in the wiring/connectors) - then the voltage will be dropped over that and the horn will see only a tiny voltage. Test it with horn in circuit - if you can - slide the rubber boots up the wires OR just add short jumpers - work backwards monitoring connections until you find the one where the voltage does not droop - clean after that...
Alan
Alan
Jumped the relay and got my horns. Worked back to the wheel to find that, per Alan, a corroded ground wire inside the hub. New wire = horn blows.
Thanks everyone.
Bob
Thanks everyone.
Bob
Solved the horn issue, and an uncooperative tail lamp socket one, too. Poured a gallon of windshield fluid into the tank to silence the messaging on the e-dash, and watched most of it leak out the bottom past a seal with tiny rip in it. Hello Roger! Win one....lose one!
Team Owner
Glad your back to being horny,
So while your messing with the washer tank,
remove the fill tube and tank inlet metal collars,
this will keep the tank free from corrosion,
But so will an empty tank
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
