928 Forum 1978-1995
Sponsored by: 928 Specialists
Timing Belt FUBAR
Old Jan 29, 2014 | 03:18 PM
928newb's Avatar
928newb
Default Timing Belt FUBAR
All the belts and the water pump were replaced by the PO in 2004 by AZtech performance in Gilbert AZ. The car has been driven for less than 2k miles and then parked for 8+ years before I got my hands on it and began to fix it up.
Since I was given the receipts for everything the PO had done on it, I took it for granted that it was OK. Today, when I decided to take the air pump out of the equation and install the 21" belt, just for the sake of it, I cranked the engine to the 0 mark and checked the camshaft gear through the peep holes in the covers.
To my surprise, the timing marks were not to be seen. I have removed the passenger side cover and found that the timing mark is on the bottom, 180 degrees from where it should be....
[IMG][/IMG]
[IMG][/IMG]
Old Jan 29, 2014 | 03:25 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
OK so spin the crank a few more times and the cams will then line up at TDC
NOTE the engine now is set at 180 degrees out of TDC
Dutch 928 fan's Avatar
Dutch 928 fan
Check if it is really at TDC. Is the distributor arm pointing towards spark plug number one?
You may have to crank one more round since the TDC mark (OT=Oben Top) passes by every 180degr.
PorKen's Avatar
PorKen
Inventor
Try rotating the crank one-more-time.
The cam bolts have been messed with, so I would check the timing with a PK32V'r.
Old Jan 29, 2014 | 03:26 PM
BRB-83-911SC's Avatar
BRB-83-911SC
Crank it around 1 more time to "0" and the cam marks should line up. The crank turns 2x for each cam revolution.
Old Jan 29, 2014 | 03:27 PM
BRB-83-911SC
Looks like everyone's on it simultaneously
Old Jan 29, 2014 | 03:28 PM
928newb's Avatar
928newb
LOL - I guess that was a brain fart...
Old Jan 29, 2014 | 03:29 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Deleted.
Old Jan 29, 2014 | 03:54 PM
John Speake's Avatar
John Speake
If the belt is 8 years old it should be changed, regardless of mileage ?
Old Jan 29, 2014 | 05:00 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
to make things easier remove the 2 top bolts on the fan shroud and then pull it clear,
this will give you much room to work
Old Jan 29, 2014 | 07:32 PM
Gary Knox's Avatar
Gary Knox
To pull the fan shroud, you MAY need to take the upper radiator hose off the radiator so the shroud can be tilted back and pulled up. Of course, first drain some of the coolant to get the level down below that hose! Drain plug is on the bottom right corner of the radiator.
Gary-
Old Jan 29, 2014 | 09:07 PM
Avar928's Avatar
Avar928
For every two revolutions of the crank, the cam gears turns once.
Old Jan 29, 2014 | 09:44 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
I bet you'll never make this mistake again.
Old Jan 29, 2014 | 09:46 PM
Adamant1971's Avatar
Adamant1971
I did the same recently so your not alone. I had my belt off and had a little freak out moment until it was confirmed that since my crank was at 45 it was all good.
And ya that's a mistake you only make once.
Old Jan 29, 2014 | 10:11 PM
JBGold07's Avatar
JBGold07
The belt appears to be riding the front lip of the passenger cam gear? Im guessing there is a fault somewhere, is this a common failure at the tensioner or water pump pulley? or even oil pump pulley? My 86.5 is exactly the same
