928 Forum 1978-1995
Sponsored by: 928 Specialists
Opinions on my cam gears, re-coat?
Old 01-08-2016, 06:57 AM
FredR
FredR's Avatar
Originally Posted by kkgmgcooke
Hi Everyone.
I read good things about Finishline Coatings. However, I am in Canada and am looking for a good Canadian provider of dry-film lubricant (also the Canadian dollar is worth only about 72cents US!). I need the 2 cam gears and the oil pump gear re-coated. I saw Fireball Coatings in Ontario...??.
Any ideas? Thanks.
Suggest you send Colin [Lizard] a PM- he is the Canadian guru on recoating these things.
Regards
Fred
Old 01-08-2016, 07:26 AM
Adk46
Adk46's Avatar
What do we know about the contribution of environment to the life of the gear coating? Is there more wear in places where blowing abrasive dust is common? The desert southwest versus Ontario?
Old 01-08-2016, 07:57 AM
DJF1
DJF1's Avatar
FYI I just bought from the local dealer a new set, with my PCA discount it was around $500 CAD for both gears which is a good price vs recoating and it would be a steal for our American friends considering the value of the USD...
Old 01-08-2016, 08:51 AM
Cosmo Kramer
Cosmo Kramer's Avatar
I had Fireball do my cam gears and crank gear, reasonable price and they turned out good.
Old 01-08-2016, 09:02 AM
Adamant1971
Adamant1971's Avatar
Received 1,097 Likes on 516 Posts
Hi Everyone.
Any ideas? Thanks.
Fireball would be my choice. They are quick and have a drop location closer to downtown if you need it. Ask for Mark.
Cheers
Old 01-13-2016, 04:15 AM
STRIKEMASTER
STRIKEMASTER's Avatar
Default bad ones?
I replaced these.
Old 01-13-2016, 10:25 AM
Chris Lockhart
Chris Lockhart's Avatar
I wonder if anyone has tried coating the cam gears with a home applied DFL coating?
I've been looking at a few that sound interesting:
http://www.techlinecoatings.com/hi-p...-coatings.html
http://www.kgcoatings.com/products/m...3000-gear-kote
Old 06-27-2017, 12:03 AM
Adamant1971
Originally Posted by GregBBRD
Re-using them or recoating them after another timing belt sequence is not going to happen.
3.5 summers and 25k km's.
Water pump has failed, leaking badly at the main shaft. Cam gears UGH.
Plan:
New cam gears
New water pump
Rebuild stock tensioner
Front main seal
New steel oil pump gear
Oil pump seal and o-rings
But glad the pump failed in my driveway.
And yes Fireball does a molly coating that works well. Last set I did where $80 for the pair IIRC.
Quick Reply: Opinions on my cam gears, re-coat?
