GTS engine FS
It is just hard to imagine lessons learned with the 928 motor didn't carry over into the Cayenne 4.5L V8 for 2003. My 2004 Cayenne motor definitely looked related..
When 911s went to water cooling with the 996, those motors were not similar to the old 911 motor. But the Porsche GT3s still used the old air cooled 993 case and were still dry sumped. That only recently changed.
I did a quick search and found very little, but this article says they are similar:
https://www.google.com/url?sa=t&rct=...58187178,d.cWc
Given the bonnet of my Turbo S is about the same height as the roof of my 928 I think it is a pretty safe assumption that the Cayernne motor is somewhat taller than tha tof the 928 which is a very compact design [too compact?] given how it fits into such a low bonnet line. I doubt there is a more squat Vee 8 motor in existence and if there is interested to know what it might be.
Having said that, if one could shoe horn a Turbo S motor into a 928 that would be truly awesome, given it is somewhat awesome pushing a 2.5 tonne dustbin truck along.
Regards
Fred
Regards
Fred
I've read that Ford did a lot of looking at the 928 motor before doing the mod8 4.6L, but buying other brands and taking them apart for study is common in the auto industry as much as learning others good ideas as learning bad ones.
Andy,
I'd gladly give you 5K for your GTS motor... Maybe even your old one, if it was in good shape.
George
90 S4 Grand Prix White (Murf #5)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
George
Lots of good info. VIN # was WP0AA2929RS820175. I believe it was from a late 94
I would buy two inferior 1R GTS motors in that shape at $5k each if you can find them for me...
At present Porsche want $16k including all taxes for a short GTS block on an exchange basis. That would include the following:
- Porsche re-worked block with new formulation alusil liners to cure oil consumption (they do work)
- crank
- girdle
- 2R rods
- genuine Porsche rod bearings
- genuine Porsche main bearings
- 8 GTS pistons with 4 out of 8 oil return holes drilled
- GTS crank
- oil pump
- oil thermostat
The assembly carries a 1yr warranty with unlimited milleage...
Thus this low mileage engine at $10k appears to be quite a steal...
- crank
- girdle
- 2R rods
- GTS crank
- oil pump
- oil thermostat
