GTS engine FS
GTS engine FS
I have a GTS (5 speed) engine with 21,000 miles on it sitting on an engine stand with a brand new timing belt, complete with alternator, starter, AC compressor, harness and both ECU's (not shown). PM if any interest. Thanks
Thanks for providing great pics, these will come in handy for further assembly on my motor . Oh and good luck with selling, i'm sure it won't take long.
Archive Gatekeeper
Unless the breather routing was changed at some point, it has the 'later' GTS crossover breather hose between the valve covers. This crossover hose is mentioned in the '93 service info, but my "late" '93 (0084, though it was manufactured in 8/92) had an 'early' breather set up without the crossover hose. Not sure if there's a cutoff for this changeover, or whether it coincided with the R1-R2 rod changeover.
Beautiful motor!
Beautiful motor!
The GTS 5 speed motor has the M28/29 designation, while the GTS auto is the M28/48. I believe the cams were different. This engine is from a parted out 94 with 21,000 miles on the odometer. I cleaned it up and put in a new timing belt. I can try to dig out the serial # if someone is really interested.
The GTS engines were designated below, no diff in manufacturing year but I do believe the engine pictured is a newer GTS engine with the cross over valve cover breather:
Received 1,542 Likes
IIRC engine serial number can be cross-referenced in the tech spec books for a better clue.
