928 Forum 1978-1995
Sponsored by: 928 Specialists
No Washer Fluid...Wheres the motor.
Old 12-09-2013, 06:48 PM
chitown928s4
chitown928s4's Avatar
Default No Washer Fluid...Wheres the motor.
So my brothers engine crapped out on his car so hes using my family car which means me and the shark will be seeing some winter action. So the washer fluid isnt exiting fom the nozzles it did work several months back. Wheres the motor. What are common causes. Thanks in advance.
Old 12-09-2013, 06:55 PM
Wisconsin Joe
Wisconsin Joe's Avatar
Pump is in the tank.
Can you hear it run?
Does the voltage drop when you hit the switch?
If yes, pull a hose off the nozzle and see if fluid is coming out (clogged nozzle).
Old 12-09-2013, 07:00 PM
uraniummetallurgist
uraniummetallurgist's Avatar
Best to start with the easiest trouble shooting first. I use a needle to poke into the washer nozzles outlets on the hood as a first step. You should also do this for the headlight washer nozzles too. Next, check reservoir level for sufficient fluid.
The pump is located just under the washer reservoir in the engine compartment.
All the best,
Joe
Old 12-09-2013, 07:03 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,838 Likes on 1,383 Posts
#1 would be plugged nozzles, roto-root them with a straight pin.
Good discussions on the rest of the system here:
https://rennlist.com/forums/928-foru...ld-washer.html
System schematic:
http://members.rennlist.com/pirtle/z..._schematic.pdf
and new nozzle discussion:
https://rennlist.com/forums/928-foru...zles-88s4.html
and
Here's where the washer tank is,
Here's the medial side of the tank, showing the headlight washer pump at bottom, and the windshield washer pump hidden behind the foam sheet:
Here's GB's newest product, a billet headlight pump blockoff plug:
Here's the typical crap in the bottom of 20+ year old washer tanks, which might be clogging your pump:
Old 12-09-2013, 07:29 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Is the tank frozen?
Old 12-09-2013, 08:34 PM
chitown928s4
Thanks Rob and Joe...poured fluid in yesterday. It did work not too long ago. Ill check to hear for motor. My kotor on my 951 was right there so I was looking for it...
Old 12-09-2013, 08:35 PM
Barry Chan
Barry Chan's Avatar
Mine was the switch, sprayed cleaner to it
Old 12-10-2013, 12:00 AM
jwbeck17
jwbeck17's Avatar
Thank you for the photos. Those pics really help me know what to look for when I decide to inspect the headlight washer setup.
Old 12-10-2013, 07:14 AM
Bilal928S4
Bilal928S4's Avatar
Do you have to remove the fender to remove the washer fluid tank?
Are new washer fluid tanks available? How much $?
Old 12-10-2013, 08:44 AM
Hilton
Hilton's Avatar
You can get the tank out without removing the fender
Old 12-10-2013, 07:33 PM
chitown928s4
Is there a fuse or something to check. I dont see anything on the fuse panel pertaining to washertank motor.
Old 12-10-2013, 07:54 PM
Wisconsin Joe
I don't know. I see fuses and relays for the intensive washer, and the headlight washer, but not the regular windshield washer.
It might be in combination with one of the others.
https://www.928gt.com/default5.htm
Old 12-10-2013, 10:11 PM
17prospective buyer
17prospective buyer's Avatar
It probably won't have it's own dedicated fuse. Probably runs off something else. You might as well just take the fender liner out and take a look at the tank and EVAP lines. The plastic "Y" for the EVAP lines commonly breaks. Back probe the pump for voltage while someone operates the washer stalk. Check the nozzles themselves for wax deposits and other crap that can get in there.
Old 12-10-2013, 10:26 PM
chitown928s4
Nozzles are not clogged so I guess im pulling liner out...
Old 12-10-2013, 10:35 PM
17prospective buyer
Yeah I guess. There is diagrams in the PET so you can follow the circuit and see whats bad. Make sure you have flow first obviously, but then check the circuit. It could be that the check valves in the hood are clogged or broken, or a hose inside the hood fell off. Here is the PET (parts catalogue)
http://www.porsche.com/all/media/pdf...91_KATALOG.pdf
Washer system diagram is on page 347.
Quick Reply: No Washer Fluid...Wheres the motor.
