Provent Part 2
#91
Cylinders from the front are 1-4 on the passenger side and 5-8 on the driver side.
What I call bays are the sections of crankcase separated by mains. Bay 1 in the front is between mains 1 and 2 and the cylinders 1 and 5 pump into bay 1. Bay 4 is between mains 4 and 5 and the cylinders 4 and 8 pump into bay 4.
The big windage / crankcase pressure problem with the cross-plane V8 is equating the pressure between bays 1 and 4 at 45 degrees and 225 degrees of crankshaft angle.
#92
I also run a similar JK baffle but without a scrubber. The purpose is mostly to shield the main vent and prevent oil sling from the crank from plugging it up. As Fred mentions this should have nominal pressure drop because of its open design - and the Provent is allowed to do its job.
Seeing your note above and thinking a little, if the stock JK baffle with mesh is fitted I wonder if at some operating point the oil throw is such that in catching the oil, the mesh in effect, because it works so well, effectively blocks up [temporarily] with oil and stops the crankcase from venting up the chimney because of the suspended slug of caught liquid?
Regards
Fred
#93
Andrew, Seeing your note above and thinking a little, if the stock JK baffle with mesh is fitted I wonder if at some operating point the oil throw is such that in catching the oil, the mesh in effect, because it works so well, effectively blocks up [temporarily] with oil and stops the crankcase from venting up the chimney because of the suspended slug of caught liquid? Fred
For car that has a more extensively modified system and/or ProVent, and that will run hard for longer periods of time, then the version of the JK baffle without the scrubber in it is more appropriate.
Horses for the courses.
#94
Mains are 1-5 from the front.
Either way it sounds as though it would be quite difficult to fabricate a solution for such.
Presumably putting the crankcase under significant vacuum [by definition] will reduce the mass of "windage" proportionate to the degree of vacuum which may have an even more significant impact on any crankcase differential pressure.
Rgds
Fred
#95
Electron Wrangler
Based on how slowly oil fill is on a car with scrubbies in the oil filler vertical stack (now gone) I'd say they can become very restrictive when heavily laden. Likely this then belches slugs of oil when sufficient pressure builds up. Maybe it can work OK for typical light duty use
Better to have a crank baffle that sheds oil based on tight flow direction reversal. John's baffle without scrubbies/mesh will do this - so does Greg Browns version.
If breathing above this is out of an oil filler - I'd think a metal '85/'86 filler could be reasonably modified to have additional similar flow reversal baffles right up the ~vertical section. However for that much fabrication probably better to build a custom solution for the same space with a better top porting arrangement.
Alan
Alan
#96
Supercharged
Andrew,
Regards
Fred
Regards
Fred
Thanks to Tony for getting this made up for me many years ago!
#97
Electron Wrangler
In my case I am seeing nothing taken out of the Pro Vent so my conclusion is that either the JK baffle is too restictive to act as a sole flow path or [more likely] I have a deeper routed problem with excessive blow by due to wear or other problems causing too much oil to pass the pistons. I hope not but...?
My next step may be to try what Tuomo has done and remove the wire mesh from the baffle and perhaps [initially] try adding the vents from the cam covers directly to the Pro Vent inlet.
Regards
Fred
Regards
Fred
It can't just be that the baffle/scrubbies are too effective - if you are still loosing oil...
I'd double check that cam cover vent 1 way valve, or start thinking about other losses (leakage, valve seals etc). Hard for it to be blowby related if none makes it out the biggest exit hole you have through the Provent... Something is odd here. For any significant volume of oil to make it past the rigs to be lost in combustion - you'd also be seeing major blow-by - so where is it all going?
It's usually pretty clear that the Provent fliter is oiled. You do have a check valve in the Provent drain line or a deep under oil drain tube? - thats a path past the provent filter element.
From my experience crank baffles help, but even full of restrictive scrubbies - they can't clean out all the oil - not even close.
Alan
#98
Fred if your Provent sees no oil then I think you need to figure out how you are losing oil.
Alan
Alan
Valve seals were new and valve stems in generally good condition when we put my S4 motor into the GTS chassis. I remain a bit suspicious of the rings and/or cleanliness of the lands. When in the late S4 the motor used quite a bit of oil but it was consistent and the PO advised of this. After installation in this chassis it seemed to use more oil and then I tried to modify to the GTS breather system- seemingly a bad move. The Pro vent oil out goes to a catch bottle at the moment and that seems to gather more or less nothing. The inside of the pro vent has an oily appearance but the gas out pipe shows no signs of oily residue.
I therefore have to assume the oil is going through the rings and thus the question why? If the JK baffle produces too much pressure drop that may explain ring flutter. Colin's solution may just alleviate the symptoms. I am also thinking of trying the JK bafle with the mesh removed and possibly vent the cam covers into the Pro Vent as well- first- just to see if I can modulate the symptoms. Perhaps I should stick the accelerometer on the car to test performance- it seems to be running OK but I do not have access to a dyno.
Regards
Fred
#99
Basic Sponsor
Alan,
As you have a version (of your design) of Colin's vacuum system would you care to share on any improvements you have seen/felt? Less carbon buildup, more power or less oil consumption?
To me all the above are a major issue to GTS owners. On any of my pre 92 cars any of these conditions are not an issue at all.
Thanks,
Roger
Thanks,
Roger
#101
Basic Sponsor
The GTS was a one big design error, starting from the asinine crankshaft counterweight design.
#102
This thread is making me think about that GT engine on ebay. A quick trip to the dump and there will be plenty of room in the basement. I'll just store the GTS engine and as AO said, consider it part of my IRA, could be a good investment, certainly not as risky as stocks.
#104
There is something to be said for not fixing what isn't broken, but when did we ever leave these cars alone?
The suggestion to swap, was partly in jest . . .
#105
Electron Wrangler
Alan,
Thanks,
Roger
Thanks,
Roger
My system is a work in progress so not ready to disclose all the details yet (only in case some turn out to be less than ideal - I have been down many of these 'dead ends' already).
Will share in detail when completed - however I've been running a vac pumped system of various types since approx end April '13 and have put thousands of miles on it. Car has never driven better or consumed less oil, so right out the gate its better. No pre-ignition, better power.
Its basically a GZ pump (like Colin) with a GB crank baffle, Provent attached via adapted filler neck (I have a new filler port direct to sump).
I am in the process of adding a new primary centrifugal AOS in front of the Provent to strip more oil - since the Provent 200 gets over oiled in the current config. This new primary AOS should strip a large percentage of the oil but as its a free flowing design it won't ever get as clean as the Provent filter element can do - so I'm trying to use both. Packaging is extremely challenging as I have virtually no room in the fenders to relocate these (which otherwise might make life easier). This primary AOS allows a larger flow volume around the recirculation loop back to the heads so the Provent only has to deal with the net blowby flow. I do potentially have fresh air flushing into the rear cam cover ports from variable VLVs in the bottom of the air filter box - however these are now set for just a max limit (12") and don't flow anything currently - since the last thing I need is more flow right now.
Ultimately these need to be set up to flush only under low blowby and up to medium total flow conditions - most likely via an additional electrically controlled recirculation flow valve. Control based on RPM and intake vac.
I intend to have a completely sealed closed loop system - this of course demands that the recirculation to the airbox (via the air pump port) be totally clean... not there yet.
Much still to be done - but the new AOS is about ready to go in. It has taken me about 6 months to adapt for it to fit where the air pump filter used to live. Partly because it's complicated, partly that I've been going slow and partly that the fit and plumbing is so tight I've had to make it over and over again.
More results later... I am completely sold on the general direction here - its just down to the details of configuration and installation.
Alan
