belt save.porkensioner?
#31
Administrator - "Tyson"
IMO the hydraulic portion of the Porkensioner should be replaced at a regular interval with everything else.
They do fail, I've seen it on the Audi's they come factory installed on.
#32
Basic Sponsor
With every iteration of the belt I recommend changing the tensioner - low cost part and you are already in there.
#33
Has anyone on Rennlist or otherwise had a 928 belt failure because of the Porkensioner? I haven't read of any but I don't read everything.
A camshaft break with the OEM tensioner was caused by? A belt break when a water pump seized wasn't a tensioner issue but the time of a warning light might be the same as the noise of the screeching belt for reaction time.
There's less parts involved in the Porkensioner therefor less parts to fail. The parts that are in the system are more robust than OEM.
Don't believe Ken said install it and forget it for ~60k but to do periodic inspection.
If folks want to rebuild the OEM unit and live with its faults so be it.......each to their own but hate to break it to you......the world is not flat!
I never said that Ken's tensioner were better or worse. They certainly are untested over the long term and statistically are unproven. Because you like the 'idea' and it seems 'better' does not make it so. The reality is the stock system works. Follow the maintenance procedures and your engine will last MANY hundreds of thousands of kilometers. Been true since they made them, true now.
If you sleep better at night with the Audi tensioner on, then have at it. You are free to do so. But to spout unproven claims and ad untrue fear mongering irritates me.
Even in the flat world they managed to sail around just fine. Never fell off either.
#34
no joke...........Kens system has been installed on a great many 928s, both of mine included with 10s of thousands of miles/kms with zero issue. Theres also the fact, as you state yourself, the tensioner is used OEM by Audi on many models with 100s of thousands of miles of proven reliability.
Indeed we are free to make choice; thx for reminding everyone
#35
I'm not against the Porken tensioner. Just that I chose to keep the stock tensioner because it keeps the toothed belt warning function because it's warning would have averted the valve crash had I and my mechanics believed it and looked farther into the cause of it going off.
#36
Basic Sponsor
Just for the record and for 69guagemans info - I have sold hundreds if not way over a thousand PKensioners over nearly six years and many owners are on their second iteration of the TB change and beyond. Were do you get your information from?
The PKensioner has been in use before I started to sell it so it is well proven.
I have personally fitted over 45 PKensioners to customers and my own cars. My own GTS has covered over 60k miles on a PKensioner and is on the second iteration of the belt.
Please check your facts.
#37
Captain Obvious
Super User
Super User
I think some of you are looking at this all wrong.
How many cars (in history) that had timing belts (not chains) have a warning system?
How many of them experience failures when proper maintenance is done?
So long as the proper intervals are taken and proper care is done, the chances of a failure is very small.
We also have 2 people on the board who have said they got the warning light, and still had the failure!
I've seen two local members who had the stock warning system and had the waterpump nearly fail on one, and seized on the other. Neither of them got warning lights on the dash. Both of them avoided a problem by hearing noises or seeing a coolant leak and turning off the car.
The amount of people that the warning system has saved has probably been extremely few.
Most who see it tend to just ignore it instead of doing a full tear down. And I doubt that had the cam gear been taken off of RKD's GTS the problem with the camshaft would have been spotted. Most don't look that deep for the minute hairline cracks that would have been there, then BAM complete shearing of the camshaft.
#38
Trust me, this is what I do for a living. Stats on automotive measurements. I work in the automotive engine and transmission measuring field and have been to hundreds of plants and have seen first hand how this works.
Using your facts, you changed the belt before 60k. How much before sixty? Doing that on the factory tensioner would as much insure not having one on the factory system break either.
I check my facts. It is why I say what I do. I know about this stuff because I eat , sleep, and breath it. It has been my job for over 20 years.
If it is indeed better I would also say that. But it is not in the numbers. When it is I will agree. But the factory system works. Always has , always will if you do the prescribed maintenance. THAT is what I am saying.
#39
oh man..........I was going to write about the Quality Assurance lab I managed for the worlds largest Telecom provider and go on and on about stats and how they can be managed but why.
Use the OEM, we don't mind...........we're using the Porkensioner.
#41
It is better than the stock system. We are talking about *belt tensioners*. The porkensioner is a better belt tensioner system from an engineering standpoint, period. It keeps the belt in the correct tension range regardless of temperatures. It also dampens belt flutter which the stock system does not do. How can you say it is not better when, for example, the stock system *disables* the warning at startup because when the engine is cold it is not able to properly control belt flutter even with that band-aid idler pulley in place?
With regards to maintenance, everyone is free to check their belt as often as they wish. The porkensioner does not magically stop you from being able to do this. In fact, I check the belt tracking regularly even though I have the porkensioner installed.
I agree with you that the belt tension warning system is a good thing to have if you are going to experience an impending catastrophic failure. But let's use the same data methodology here... 1) what is the probability this will happen and 2) what is the probability that when it happens, the warning system will save your engine? I would say extremely small, and them quite small.
I understand your point of view, but if everyone thought like this about everything, we would still be using vacuum door locks. It's difficult to have innovation when you need to wait for volumes of data in order to accept something new, especially when it is very easy to see from an engineering standpoint that an alternative newer system is superior.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
#42
Jesus. Everyone pick their gamble and go their ways. This thread is almost as stupid as when the vendors start sniping at each other.
portensioner = more consistent belt tension at the expense of a warning.
stock = warning light and original engineering.
pick your poison and live with it, we're not getting anything useful out of this discussion here.
#43
For the original poster:
if you choose to replace all the gears, the water pump, the belt and the tensioner then use fresh coolant changed on the regular interval you will enjoy many trouble free miles and years. Inspect the crank and oil pump seals and the camshafts.
I wouldn't shop around on Ebay for the parts..............call Roger or another dedicated 928 Porsche supplier, they'll sell you the correct parts for a reasonable price. Its the cost of owning a rare Porsche sports car.
Good luck
Good luck
#44
Addict extrordinare
#45
