Cleaning AC/Vent System
Hello,
I recently bought a 1987 S4.
Now I'm in the middle of cleaning and detailing the interior. Despite the fact the the interior is really in a great shape (everything looks almost like new), there is this smell and I want to get ridge of it.
I cleaned all the interior and the carpets. It's much better, but I also want to clean/desinfect the AC/vent system.
I bought a spay that needs to be sprayed into the intake of the AC/vent System. Has anybody done this already? What was the result and where is actually the intake.
Thanks for your comments.![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Volkmar
Volkmar
Pop your hood and by the windshield is a plastic "cowl" cover. Pull it and on the passenger side you will find the blower motor (semi-circular) and a rubber boot. Pull the boot aside and this will give you some access to the evaporator. Which is where all the gunk accumulates. You will want a flash light to see inside as it is a tight fit.
Post your results on the forum that Sean gave you about cleaning the evaporator. More information in one spot is better than in two.
