87s4 aut havoc knob tab broken
On climate control small levers that go side to side for temp adjustment and settings for climate control...they are sliding tabs...
I can probably glue it back on...just wondered if anyone broke theirs and if there is an alternative fix....
There are multi-filament fiberoptic cables fed into these for their illumination. They are removable, but you have to remove the unit and do it right. Pulling them off will break the tabs that hold them in their place. Do a Search (I think Dwayne may have it in his) and find how to properly remove the faceplate and slider *****.
Go to this link for Dwayne's write up on how to remove the HVAC unit as well as how to repair the broken slider *****.
http://dwaynesgarage.norcal928.org/1...0Procedure.htm
Under the Lift
As Dwayne shows, you replace the broken sliders. Glue won't hold. They are inexpensive.
http://www.mailordercentral.com/928i...574%20498%20KT
