928 Forum 1978-1995
Sponsored by: 928 Specialists
Transmission valve body components
Old Nov 5, 2013 | 04:12 PM
Tony's Avatar
Tony
Its starts...It drives..it shifts(very nicely i will add)....and with all gears!
Got the fluid in this morning and drove about 30 miles..freeway..around town.
All is good at this point.
In short it was dirty fluid, dirty valve body...dirty filter caused by disintegrating friction material.
the transmission will be coming out shorty, put aside for a rebuild and the spare with LSD put in.
Ive got some great valve body pictures to organize and post when i get to it. Here's one below.. Hopefully these shots will end the need to look at the ATSG and various MB manuals etc for assembly reference. Not one of the images in the manuals i looked at is exact to our specific transmission type. There are some very subtle differences among the components even with in our own units. The picture of the check ***** is an example....one of those ***** is different and goes in a specific spot. (it isnt the one on the spring either...look at the reflections)
more later.
time for a
File Type: jpg
File Type: jpg
Old Nov 5, 2013 | 04:21 PM
Darien's Avatar
Darien
Great to hear How does it shift with Boost?
Old Nov 5, 2013 | 04:32 PM
Tony's Avatar
Tony
like it usually does...1-2 is solid... I still have that slight 2-3 flare though..3-4 is fine.
Im not going to be hard on this unit at all considering the friction material is coming apart inside.
Trust me Darien it was a big relief as i drove down the street and it shifted. Actually, first, i backed it out of the garage 3 feet then put it in Drive, just to make sure i actually had gear selection and it was OK to head out.
Old Nov 5, 2013 | 06:34 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Tony:
Even if the repair is shortlived, your documentation (more to come I trust) will be invaluable. Thanks again.
Old Nov 5, 2013 | 09:30 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
Originally Posted by 1989porsche928
dont get the springs mixed up. some of thoose can't be ordered. the valve bodies received a few upgrades throughout the years.
There are subtle changes, virtually every model year.
Old Nov 5, 2013 | 09:38 PM
Tony's Avatar
Tony
Lower valve body parts...
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Nov 5, 2013 | 09:41 PM
Tony's Avatar
Tony
upper valve body parts
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Nov 5, 2013 | 09:46 PM
Tony's Avatar
Tony
Check ball locations and other parts..
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
AO's Avatar
AO
Supercharged
Hey Tony,
Great work. Glad to see you keeping at it. ALso happy to hear that it is better, albeit still slightly sick.
Great documentation as always!
Old Nov 5, 2013 | 09:56 PM
Tony's Avatar
Tony
Valve body installed..note the short bolts!
File Type: jpg
Old Nov 5, 2013 | 10:04 PM
Tony's Avatar
Tony
Originally Posted by AO
Hey Tony,
slightly is an understatement seeing what was in the pan. Considering it has 178K miles on it and now at this power level...it needs to be put right/replaced asap.
there was no way i could do this with out taking pictures(even then i messed a spring up),plus, i was frustrated at the various manuals as far as images.
Old Nov 5, 2013 | 10:10 PM
Tony's Avatar
Tony
Hooked up to the home made IV
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Nov 5, 2013 | 10:21 PM
Tony's Avatar
Tony
Valve body TOP
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Nov 6, 2013 | 01:40 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Brilliant job. Should be pinned and in the DIY section. Also, I often look at stuff you've done on your website. Add this if you haven't already.
Old Nov 6, 2013 | 08:43 PM
Glen McCartney's Avatar
Glen McCartney
Absolutely great work Tony, wish this was out there before I did my VB work. Interesting that the manuals list all the check ***** are the same size and that you had one that was rubber/matte finish and different size. All 18 in mine were shiny and same size.
