What Is It?
I know others have somehow wiggled their hands into the abyss and managed to change the clutch master cylinder with all systems in place, I took (what I thought) was the easy route by removing the brake booster and doing a general clean-up while I was at it.
In cleaning the reservoir, there is a rubber cover over a spring loaded 'switch' that you can depress. Here it is without the rubber cover. What is it, and what do it do?
When you pulled the booster, did you push in the brake and secure the MC rod w/a clamp plate?
Jim, I'm going with Mike's test switch answer. Sounds right to me.
Yes, I did push in on the brake pedal and secure it with a clamp...which flew off the minute I released the brake pedal. So, I clamped the rod with a small set of Vice Grips, and took 2 swipes at it per the WSM. It still was a couple of mm protruding too much to allow me to rotate the booster out.
So, I used a screw driver behind the Vice Grips to exert just a little more pressure and that got me what I needed. Not elegant, but it worked.
What is really needed is a threaded shaft on the booster that allows you to pull the rod out. How do we do that, Jim?
Here's a couple of photos:
Team Owner
to pull the booster rod out,
simply get a piece of gas line hose slide it onto the rod then get the vice grips and clamp it ,
it wont move till your ready and no marks on the rod.
Ahh the other point to remember is that the seating surface of the MC to the booster is a precision fit ,
and if you scratch this surface then you may find your brakes wont work as well as they should,
since you will have effectively created a vacuum leak to the booster.
There is also a rubber seal thats in between the booster and MC but a scratch will make the seal difficult
I'm going to work-up a bracket for the rear of the booster. I'll source parts tomorrow and cobble it together. If it works, I'll shoot it up to you.
I has a small spot of surface rust on the bottom of the booster, and after sand/prime, I hit it with the Eastwood Chassis Black and now it's clear that the whole booster will look amazing painted. Like you, I need to get that plate off to do it right.
Bob
Bob
