Headlight Height Adjuster Overhaul
#46
It'd definitely not going to work as it is now. The ball has not enough left to keep it inside the actuator.
I'm afraid tape alone will not be sufficient either. Can I get the actuator out of the car, or is it a no-go to disconnect the hydraulic tube from the actuator?
Based on PET, the whole assembly is one part, and you can buy it like this from the regular suppliers.
The other end contains a bolt that you can unscrew and then put the plastic axe with the ball.
#47
There's a factory part for that..
You need two of 928 631 201 02. You then remove the actuator, and the part fits in its place, and attaches at the other end with the ball-cup arrangement like the dumbell on the actuator. I fitted them to my 89 about a decade ago.
Pic from PET - its item no. 6
I rarely use the car at night but when I do is generally fully loaded with wife kid and luggage and now that i installed the woodypeck led lights i am afraid I might be blinding other drivers cause i see the lights are quite high
