Which one is temp sensor?
Just took this pic of the left side of my 90 S4 auto trans, which one is the temp sensor? I'm guessing the brass one but just wanted to be sure. Thanks.
Yep, the brass one is the trans temp sensor.
Team Owner
and when you remove it the whole cable must be turned or you will damage it
Inventor
The other is the transmission protection switch (for the EZK).
(The green thing is the vacuum modulator.)
Team Owner
I thought I would link this repair as well .
Transmission protection switch fix for leaking
NOTE this repair is for the knurled cap under the brass temp sensor.
https://rennlist.com/forums/928-foru...tection+switch
Team Owner
follow post 3 to remove the temp sensor,
think of it as an O2 sensor where the whole cable must be turned to unscrew the part
I'm certainly not an auto engineer but why have a temp sensor way back at the trans in the engine cooling fans circuit, makes no sense to me.
https://rennlist.com/forums/928-foru...o-shutoff.html
I've noticed a few GTS's that do not have this installed so I'm going to try and see what getting rid of it does on mine. Can't say if all of them do not have it as I've not looked at all the GTS Autos I've had in here.
Team Owner
that part connects in the spare tire well,
thats where I would look first,
the part screwed into the trans is simply a thermocouple.
not much to see
not much to see
