928 Forum 1978-1995
Sponsored by: 928 Specialists
Can I test the green wire?
Old Aug 27, 2013 | 04:50 PM
bran3b's Avatar
bran3b
Default Can I test the green wire?
is there a way to test the green wire on my '81? It looks fine but everything else checks out. I mention what I have done so far in my other thread "'81 revival" but wanted to start a new thread since this is a specific question. I have replaced the fuel pump and have 30psi at the rail. I checked the Injection relay and it is working, I can hear it and when I energize it the current flows properly. I have hooked up a noid light to one of the injectors and it flashes as I crank the engine but it looks weak. Basically I am at the point where I am starting at the beginning and re-checking everything but the one thing that I don't know how to test is the green wire.
Thanks.
Old Aug 27, 2013 | 05:01 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
to test the green wire install a new green wire then turn the key.
If the engine starts then your old green wire was bad.
Otherwise if your green wire is faded tan, brown, black ,or the insulation is cracking ,
or the connector ends are crumbling its time to replace it
Old Aug 27, 2013 | 07:38 PM
fraggle's Avatar
fraggle
Gads these should be some way to test or replace this wire with something simpler, it's just a shielded something something with a given resistance!
Old Aug 27, 2013 | 07:44 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
It would be nice if the wire was less expensive,
BUT since its Bosch parts its also Bosch quality,
and thus it will last another 25 years without causing further running issues,
That should save a few towing bills,
pay now or pay later
Old Aug 27, 2013 | 07:45 PM
FBIII's Avatar
FBIII
I despise replacement mechanics as I am a cheap SOB. I can't see why you can't check resistance while bending the wire and wiggling the terminals.
Old Aug 27, 2013 | 07:59 PM
fraggle's Avatar
fraggle
I don't mind replacing a part I've tested, but really a wire is a wire, it is a conductor bundle that meets a set of specifications, it isn't magic. I play with RF generators and plasma systems for a living, this can't be harder.
Old Aug 27, 2013 | 08:17 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
FBIII I think your terms are conflicting.
What you should say is that you hate replacement technicians.
These guys just swap in new parts and could not fix any of the parts they remove.
A mechanic is capable of fixing subsystems and parts of them.
AND,
is also smart enough to know when fixing a broken wire without replacing it is only going to cause issues after the engine is running when it leaves his shop.
Like after a car wash or rain storm,
how many times have you read that thread,
I washed my car and now it wont start
It will only take one tow truck trip to pay for a fouled green wire, when its old and cracked and the ends are crumbling its time for a new part, plain and simple.
The damage to the wire is what you cant see on the inside of the insulation.
I am quite capable of fixing many things on the 928 instead of replacing many of the parts they contain..
HOWEVER I am also smart enough to KNOW that the green wire is best replaced with the new correct part , as there isnt any such wire thats been capable of a substitute that will perform flawlessly for another 25 years like the original Bosch part will do...
So please dont think that I am being smug with my answers,
I have spent more than a few times chasing ignition issues only to find that the cause is a bad signal being sent to the computer, and installing a fresh Bosch green wire makes the engine run perfectly, and for quite a few years to boot
Old Aug 27, 2013 | 08:52 PM
FBIII's Avatar
FBIII
I was referring to the process not the individual. As far as his wire is concerned we do not know it is damaged. All we know is what has been replaced. And until someone convinces me otherwise a green wire is a wire and can be tested for resistance. We all been dabbling with 928's for some time. It is quite possible I have been dabbling with them quite a bit longer than even you.
Old Aug 27, 2013 | 09:12 PM
bran3b's Avatar
bran3b
ok, ordered a new green wire. With 2 cars one is bound to be ready for one either way. The one on the '81 is definitely more brown than green so I will swap it out and report back.
Old Aug 27, 2013 | 10:03 PM
fraggle's Avatar
fraggle
No smugs or abrasives intended or taken, replacement of the green wire right now is a relatively easy option, but I'm thinking down the road Bosch will quit supplying the things. Similar wires exist on several vintage Porsches and I think it will be advantageous to end source a replacement someday.
Old Aug 27, 2013 | 10:28 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
I'm guessing that Stan has replaced a whole bunch of "green wires". I'd guess that I've replaced over a hundred, over the years. I keep multiples, in stock. Hell, Mark Anderson once bought a really nice early car which would not run (been to multiple shops and the owner was tired of paying people to trace the problem and instead of towing it over and having me fix it, I took one look at it and suggested he just replace the green wire.....since it was original. Fixed. He had bought this really nice early car really cheap (it did not run) and sold the car for a very nice profit.
There are some pieces that are cheaper to just replace, instead of sitting around trying to figure out what "could" be wrong. Labor/thinking/tracing problems is expensive.
Here's how I determine if I put in a new green wire:
If there is voltage at the coil and there is no spark....it gets a green wire.
That only fixes 99% of the cars....but it also only costs about $15 worth of my time to come to that conclusion....and another $15.00 worth of time to install a new green wire. Pretty cheap repair......for a 99% return. (I use 99% as just an estimate of the cars, which did not have spark, that the green wire repaired. I've never seen a bad C/D unit in an early car. I've only ever seen 1 bad "coil" inside the distributor, which generates the signal. The remainder that had voltage at the coil, yet no spark, were all green wire problems.)
Old Aug 27, 2013 | 10:48 PM
ROG100's Avatar
ROG100
Basic Sponsor
The issue with replicating the Green wire is the connector at the distributor - John Speake had a replacement and I sold it for a while but continued production was dependent on receiving a useable core connector.
They were mostly none usable and the replacement wire died a natural death.
At $128 this is a part that should be replaced on all cars of that era if they have the original.
The same as replacing the CPS on the later cars.
Old Aug 27, 2013 | 10:52 PM
MainePorsche's Avatar
MainePorsche
Originally Posted by ROG100
...At $128 this is a part that should be replaced on all cars of that era if they have the original.
It's like shaving. We'd rather not (daily), but you just gotta do it.
Old Aug 28, 2013 | 12:03 AM
Jetdriver69's Avatar
Jetdriver69
I couldn't agree more. As I was doing an intake refresh, I discovered the green wire was held together with black tape and rotten at both ends. So Roger sent me a new old and I added new plugs, wires, cap and rotor and refurbed injectors from Witch Hunter. It runs great with no hesitation, but the engine seems to like 27 degrees advance much better than 23 degrees.
Old Aug 28, 2013 | 12:08 AM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Get off your high horse, would yea?
I gave the green wire off my 79 to a friend that is an EET with every known piece of testing equipment short of a NASA lab. He found nothing wrong with it yet replacing it fixed my WOT miss. Put the old wire back on.... the miss returned.
It's a wear item that lasts 25+ years that gives the source signal for your fuel and ignition.
My time is money, the effort that goes into testing one of these pales in comparison to the cost of the wire and the length of time to replace it. The ratio goes through the roof for most 928 owners that pay someone to work on their cars.
