Front wheel well splash shield "sealing strap"
Has anyone found a better aftermarket foam material for this piece? Mine were completely rotted away, looked like open-cell foam that was not dino product resistant.
I used some black weatherstrip closed cell foam strip rolls from Home Depot and just stuck two strips together for the appropriate thickness. That way none of the sticky part touches anything. I forget the width bit you can just measure the shield groove and buy a width so that it protrudes enough from the groove to get a seal. Works great!
I sourced OE material from Automobile Atlanta. It is a very different type of foam with a 'finish' on it that allows it to slide into the channel.
I thought about using backer rod like that but was afraid it would squeek - and I see you are doing the same crack repair job! I'm using sheet aluminum, a little heavier (steel would be better except for corrosion) and pop rivets.
Thanks again all for the suggestions!
