Throttle Cable Wheel Issue.
Guys,
Forgive my simple questions.
I removed the C clip and the wheel still is held on by what looks like a washer. I don't want to force things. I've PB'd it and doesn't seem to want to give. Any pearls from those who have been there before.
Thanks,
Craig
Thanks,
Craig
Yes, Bertrand that is what I see too on PET. W
When I remove the circlip it resided between the top lip of the post and a bottom lip. The plastic wheel rides BELOW this bottom lip, hence I can't lift the wheel up and off.
Sorry I can't post a pic. My SLR was left in the rain - teenage kids !
They only look a little less 'shiny' then when I dealt with them year and a half ago.
Much better now to deal with the CPS.
Looks like a Dremel will be employed. Allen bolt is rusted down quite a bit. Without even attempting removal the tool just turns in it.
Well, here we go.
Nothing else but the circlip. I used a puller to get it off and more or less destroyed it. Corrosion makes it impossible to remove it normally. Ordered a new wheel, used some fine grit paper on the shaft and lubed it up good. The new wheel turn much lighter than the old wheel.
What you are seeing that looks like a washer on the wheel is its bearing. The plastic wheel gets brittle with age, so you are wise to leave it alone unless you want to replace it. Good luck with the CPS. If you can turn it, that's hopeful. They are often very stuck and will break off. Drilling is not fun but the only other option I know to get it out in that case is to remove the flywheel.
