GTS Cam pics
Partial hijack: I've got a set of GTS cams that were in a nice enough shape that I didn't have the heart to experiment with (i.e., destroy) them. I'll sell them if someone wants to restore a GTS. If someone wants to just drive a fun car, these are not the cams to use -- put in much bigger cams with more overlap and have more fun.
Former Sponsor
Just saying it is not very common and that people with small pits, in their cams, should not be concerned.
The 4-valve spring loads, valvetrain weights, tappet diameters, and camshaft accelrations are such that it's difficult to get stresses there that would wear the cam lobes. However, 2-valve heads are a completely different story.
Here is what mine looked like and on the very tip there is some pitting
![](http://i103.photobucket.com/albums/m158/bwmac/Brads%20Porsche/IMG_0805.jpg)
But I used some 400 grit scotch brite pads like these
http://www.3m.com/product/informatio...-Hand-Pad.html
and this is how it turned out.
![](http://i103.photobucket.com/albums/m158/bwmac/Brads%20Porsche/IMG_0829.jpg)
[IMG]http://i103.photobucket.com/albums/m158/bwmac
/Brads%20Porsche/IMG_0828.jpg[/IMG]
So that said I dont think your cams are that bad but it is also hard to tell in a picture.
Also as you can see, most of the embedded material in the cans will polish off.
My 2 cents
My 2 cents
Let's see them in 10,000 mi.
With a couple of UOA readings.
Denial is ok, as you're a good swimmer.
Rainman
Wondering if there are any long-term updates available for this pitting situation as I find myself in a similar spot, small pits on the nose of the lobes.
Really nothing much to worry about, or something that a light polish can take care of?
