Please help identify my transaxle
The shifter coupling was disconnected when I got the car on the trailer...still is...I believe I have the trans in neutral, but I'll confirm next time I'm at the shop...
Did the LSD cars come with a LSD additive in the gear oil i wonder? Newer cars commonly use a limited slip additive as a friction modifier, such as graphite.
G28/13 2J10708 is 208th '88 MY manual box and it has LSD. 2 before '88 MY letter J says it has LSD. 1 would be open diff and 3 PSD. This numbering format was used in '88-95 MY.
Plates in LSD can be so badly worn that other side will turn opposite direction even when gearbox is in neutral. It just means other drive shaft is easier to rotate into opposite direction than get pinion shaft to turn inside gearbox. This is very extreme case and LSD is definitelly in need for rebuild.
Former Vendor
If that is the case....you are going to need more than just new friction discs. These limited slips are generally very neglected and lots have had the wrong gear oil in them. I'm seeing more and more of the big pressure rings that are destroyed from the friction discs galling them....ao many that I keep them, in stock.
Pull it apart and lay it out on a bench and let us see what the parts look like .... or take it to someone who can rebuild it for you.
They really are quite easy to pull apart and you get a good understanding of how and why they work when you look at the innards ... just open it up and lay the parts out as you see in exploded parts diagrams.
Former Vendor
Team Owner
the upside to fixing all of the subsystems on the car at the same time is that,
when its put back on the road,
it will drive better than just about any other new car you could ever drive.
My 83 S has LSD, and works properly. AFAIK it calls up standard GL5 oil...thats what its had for 10+ years, and it still works. The later models may of course be different...
jp 83 Euro S AT 55k
jp 83 Euro S AT 55k
All the G28/13 transmissions that have had a stock LSD in it have had a /12 after the 13 to denote the LSD.
Errka is normally really good at this stuff. But I would remove the fill plug and verify, my money is on an open diff.
Number system in tech spec book changed for 87 up, no longer a 12, instead. a 2 designater. Try it on gravel , you will likely find it is working well such that it can be a lower priority item in your punch list (note also greg's point about checking in neutral v. in gear). Counter view, the guys advising rebuild are the best of the best, and basically say the units rarely don't need rebuild. I'm speaking more towards priorities on what must be a moderate sized punch list.
