928 Forum 1978-1995
Sponsored by: 928 Specialists
looking for 928 help/advice- Norcal
Old Jun 5, 2013 | 02:03 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
I'm in the East Bay, near Walnut Creek. I'd be happy to let you drive my car and we could talk about 928 issues, but I'm not that well versed on early models. There are common wear and maintenance items and fluid leak points on all models, not unlike any other car (balljoints, tie rod ends, suspension bushings,motor mounts, pan gasket, cam cover gaskets, front and rear main seals, wheel bearings, trans mounts, steering rack, etc.) and pretty well known electrical weak points (relay, relay, relay) along with some front wheel alignment nuances that are often screwed up. If the car starts easily, runs smoothly, idles at the right RPM, has stable manifold vacuum, has good power, drives straight, handles well, is dry underneath, feels tight with few rattles, doesn't make any odd noises other than "bwaaaahhh", has good paint, a clean, intact interior, doesn't grind second gear if manual or slip between gears if auto, it's worth going further. In fact, that would be rare. Most 928s of that age have some issues. Then it becomes a matter of determining whether they are major. Any cosmetic issues are going to call for major dollars unless you can live with them as is, so good cosmetics (intact dash, pod seats, paint) is a real big plus. Compression and leakdown are always a good idea, but the engine is pretty durable (my car is proof), and if it runs very well and is low miles, you might forego that, but there is a shop on Campbell (CT Automotive) that has a good reputation for servicing 928s where I think you could get a PPI with that included.
Anyway, let me know if you want to come up this way sometime soon.
Old Jun 5, 2013 | 02:38 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
Originally Posted by granprixweiss928
the car in question is an 81, white/black, 5 speed. 7 slot wheels, 56K miles. VERY clean in/out. records.
Im a car guy, I know car mechanics quite well. Just not so much 928s. but I know the differences in MYs, been doing my research. Its the key list of things to look for. commonly broken items, spongy brakes?, play in steering? motor mounts? broken body parts? etc.
thx
The biggest problem, with low mileage older 928's, is from the coolant tuning acidic and "eating" at the head gaskets, heads, and block. Very common, on cars that sat for many years and got driven very little. The coolant needed to be changed every two years.....especially in the "early" days. Today, coolants are much better and you probably can "get away" with changing the coolant every 5 years.
Old Jun 5, 2013 | 02:59 PM
MainePorsche's Avatar
MainePorsche
Flush/clear it out well, and use distilled water and Xerex G 05 for your coolant. Also use 'Water Wetter'.
Old Jun 7, 2013 | 11:45 PM
granprixweiss928's Avatar
granprixweiss928
so the car Im interested in, is in Socal. Any Socal members available mid week to join me one afternoon for a few hours to help look over the car and drive? the car is an 81 so a long time experienced owner of an early car is welcomed, mainly looking for eval on the sounds the car should make, and how it drives. thanks!
Old Jun 8, 2013 | 01:30 AM
Speedtoys's Avatar
Speedtoys
Where?
Old Jun 8, 2013 | 02:24 PM
granprixweiss928
north-west Los Angeles.
