928 Forum 1978-1995
Sponsored by: 928 Specialists
Compression test Numbers 87 auto
Old May 19, 2013 | 10:08 PM
firemn131's Avatar
firemn131
Default Compression test Numbers 87 auto
Getting ready to pull the engine for MM/OPG, TB/WP, Refresh..etc..
I wanted to get some base line compression numbers. All are close to each other..
However, here is the range. From 97 to 108..
Car runs great, aren't these numbers off by about 100?
so, what are the compression #'s supposed to be.
I ran the car and had it up to operating temp. Parked it and had all plugs out in 10 minutes. Compression tester in, WOT turned for about 6 turns..
thnx
Old May 19, 2013 | 10:14 PM
SeanR's Avatar
SeanR
Why are you pulling the engine/
Old May 19, 2013 | 10:17 PM
Lizard928's Avatar
Lizard928
Compression tests aren't very good. A leakdown test is a far better engine check.
Agreed with Sean, why pull?
Old May 19, 2013 | 10:22 PM
rgs944's Avatar
rgs944
You could do a lot better job of cleaning but I would sure not pull the engine to do what you are planning. Have you been to Dwaynesgarage site yet?
Old May 19, 2013 | 10:32 PM
firemn131's Avatar
firemn131
Yea, I know I can do all of that with the engine in. But it is so filthy and wiring needs work, I just want to clean the engine and bay.
After I pull the engine, I am bringing in my sons 968 to do a FOES. I found his car in a junk yard for $2000.00. the mechanic who had it couldn't figure out the variocam system. I think I can get this car running for about 300..
I am in no hurry to have the 928 back on the road...just gonna make it perfect..Plus to be honest, I have found that you learn so much when you pull the engine..The best part is that my 12 year old son is gonna get schooled.
I was wanting to do a leak down, but couldn't find the correct gauge set up.
I have been to Dwayne's and have made binders of lots of his info..
I am also doing a power steering rebuild.
Old May 20, 2013 | 01:06 AM
FredR's Avatar
FredR
I typically see about 185 psig and pretty much even numbers at that last time I tried it.
Have you calibration checked your gauge at all? I usually crank my engine about 3 seconds. If that was your real compression pressure I think you'd be driving a sick car.
Regards
Fred
Old May 20, 2013 | 02:19 AM
joejoe's Avatar
joejoe
When testing did you hold throttle open?
Old May 20, 2013 | 10:07 AM
Dan87951's Avatar
Dan87951
Wow, your engine seems tired. Do a follow up leak down test as well. Have you been in a proper running 928? I bet if you did you would be amazed at the power increase.
Old May 20, 2013 | 10:33 AM
fraggle's Avatar
fraggle
Mine was, cold, 193-195 with new headgaskets.
Old May 20, 2013 | 11:07 PM
firemn131's Avatar
firemn131
I ran the car and had it up to operating temp. Parked i5 mph and charge ont and had all plugs out in 10 minutes. Compression tester in, WOT turned for about 6 turns..
I am thinking the gauge must be bad..Car runs great...it will break loose at 35 mph and charge on. rolls easily past 140...idles great, doesn't burn or use oil. I wont drive it at all on wet roads. it just has so much torque, the slightest bit of too much pedal on a wet road and we in for a wild ride...
Old May 22, 2013 | 12:05 AM
firemn131's Avatar
firemn131
new gauge..good results
172-183
