Brake Upgrade Question
Hello, I have a 1985 928 Euro 5 speed. And I have an oppertunity to get the brakes from a 1987 928 S4. Will these brakes be an upgrade worth the expense? Seller is asking $600 for Calipers, Rotors, and Hoses. What will I have to do to put them on my car?
You'll need the front control arms and spindles from the S4, or you'll need early spindles, adapter brackets, and 993 front rotors. The rears just require some thick washers to shim the calipers, but you can certainly get the rear hub carriers and put them on.
You would want the front control arms to go with the calipers. Rears bolt on. $600 is a decent price for the parts. Front rotors will be about 3/4" bigger than what you have.
But is there a need to change over apart from the looks? I've read several times that people that have done the swap actually did not notice an improvement over the S floating calipers...
It's eye candy. They look awesome but the S brakes are more than you'll ever need. Not worth the trouble in my opinion.
Team Owner
didnt a few others simply buy adapters to mount the front calipers Ken Rudd for example?
the rear calipers should bolt on and the backing plate should be swapped as the rear rotors with the S4 brakes are bigger.
Same for the front backing plates. that way you keep the ABS if the car has it,
Thus no swapping out LCAs or spindles or upper control arms
Former Sponsor
I have not tried the pieces that Ed Standke is making.
The "correct way" to do it is with all of the '87 control arms, spindles, and uprights.
Big improvement in braking, BTW.
Bart-Jan-
Check these threads:
https://rennlist.com/forums/928-foru...-for-86-a.html
https://rennlist.com/forums/928-foru...s-on-85-a.html
https://rennlist.com/forums/928-foru...e-upgrade.html
They all relate to similar situations. On my 86, I ended up using the PerfexMfg kit to mount GTS Calipers to my stock 86 front spindles, and a couple spacers/washers to mount rear S4/GTS ( same) calipers on the rear. This let me keep my stock ABS. I had to tweak some dust shields as well, but that was minor. The Perfex kit is designed for GTS calipers, but contact Ed Standke ( on this forum or at perfexmfg.com) to see about S4 caliper application.
For street use , the S3 brakes are certainly adequate. However, I can tell you from experience they are not adequate if you plan on using your car at the track on a regular basis.
The ball joints end up hitting the rotors, when using any of the adaptors that I have seen. The ball joint can be "ground down" some, but they still hit at the extremes...unless you grind on them until they are "unsafe".
With S brakes at Fontana where we run the front straight go through turns one and two on the gas before slowing for a quick 90 degree left and right......with race pads I found that I was pushing pretty hard on the pedal as I got close to that 90 left turn thinking it was probably good that they just coned off the back straight !! The old very brown is not that fast but was rolling pretty good on that big track.
That said for "normal" street driving at reasonable speeds S brakes can work very well they just lack the extra rotor mass, extra leverage for modulation, and somewhat bigger pads with staggered size 4 piston design, and the cool PORSCHE logo.
Former Sponsor
If you are running the S-4 rotor, along with that caliper, on an '85/'86 spindle, it is virtually impossible for the ball joint to not hit....
