928 Forum 1978-1995
Sponsored by: 928 Specialists
Compression test values for 4.5 liter
Old Apr 24, 2013 | 10:39 AM
Jetdriver69's Avatar
Jetdriver69
Default Compression test values for 4.5 liter
The 82 I recently purchased had a compression check done about 2000 miles ago. Anyone have the stock values for this engine? Thanks!
Old Apr 24, 2013 | 11:43 AM
chrisjbell's Avatar
chrisjbell
Plenty of good info in this thread:
https://rennlist.com/forums/928-foru...st-values.html
One of the key bits of info is that the actual numbers are less important than consistency across cylinders.
Old Apr 24, 2013 | 12:39 PM
Jetdriver69
Mine are 160 across the board plus or minus 5. The engine has 83K and has never been cracked open for any reason. Wouldn't the compression test numbers be different on the newer engines (5.0/5.4 liter) due to the factory increase of compression ratio?
Old Apr 24, 2013 | 02:07 PM
IcemanG17's Avatar
IcemanG17
those are solid numbers for an 82 L jet....its a factory 9-1 CR engine and with cam timing factored in the ideal cranking pressure is about perfect
Static compression ratio of 9.0:1.
Effective stroke is 2.71 inches.
Your dynamic compression ratio is 7.98:1 .
Your dynamic cranking pressure is 158.46 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 0 PSI is 7.98 :1.
V/P (Volume to Pressure Index) is 113
Old Apr 24, 2013 | 02:35 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
Where did you find this calculator?
Old Apr 24, 2013 | 11:15 PM
Jetdriver69
Sorry, I looked at the test sheet wrong. My numbers are 155 average with 150 as the low and 160 as the high. So according to your calculations, right on the money. Good news anyway. Thanks!
Old Apr 25, 2013 | 03:45 PM
IcemanG17's Avatar
IcemanG17
i got the calculator from www.wallaceracing.com Lots and lots of calculators on there....stuff I don't understand at all
