928 Forum 1978-1995
Sponsored by: 928 Specialists
Compression test values
Old Mar 1, 2013 | 11:20 AM
EMan 928's Avatar
EMan 928
Default Compression test values
Could someone tell me what I should expect for compression test values for a 1993 GTS with 70k miles? Doing a test as I write this at an Indy shop and coming up with the following values for 1-4:
#1 160/178
#2 142/160
#3 160/180
#4 150/162
Note that my battery is fairly weak and we're not getting as much ooomph when we crank it over, which may affect the numbers a little bit.
Thanks,
Old Mar 1, 2013 | 11:31 AM
EMan 928's Avatar
EMan 928
Values for 5-8:
#5 130/140
#6 110/120
#7 160/180
#8 150/170
Old Mar 1, 2013 | 12:00 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Try again with fresh battery.
Old Mar 1, 2013 | 12:05 PM
Herman K's Avatar
Herman K
That looks like you have way to much variance should be around 180 +/- 10% all around.
Did you use a digital gauge (way more accurate and they keep each cylinder in memory) http://www.ebay.com/itm/Mityvac-MV55...c858ff&vxp=mtr
Old Mar 1, 2013 | 12:43 PM
davek9's Avatar
davek9
Just got off the phone w/ Erick, the engine was also stone cold (should be at least warm).
I suggested he also tries a leak-down test, but I'm leaning toward this is carbon on the valve seats.
Dave
Old Mar 1, 2013 | 12:58 PM
oups59's Avatar
oups59
If I remember correctly, mine was between 190-205
Old Mar 1, 2013 | 02:27 PM
depami's Avatar
depami
Dave
Cold shouldn't matter if he does it wet.
But you really want comparison between dry and wet so warm is definitely preferred.
Is that what the 1st and 2nd #s are, dry/wet?
Also, you should have at least five revs for the reading to "pump up" so cranking power could be an issue.
It helps if you pull all the plugs so you’re only cranking against compression of one cylinder.
Old Mar 1, 2013 | 04:16 PM
EMan 928's Avatar
EMan 928
Thanks, Depami.
For the first and second numbers, indy mechanic cranked 3 times as the low, took the reading, then 3 more times and took that final reading as the high.
Engine wasn't run in 24 hours and the shop was 60 degrees room temp. And he had the 4 spark plugs removed on one bank when he performed the test (other bank still had the spark plugs installed)
Old Mar 1, 2013 | 05:27 PM
GlenL's Avatar
GlenL
The important part is to be consistent with each cylinder and then look for consistency across the holes. Remove all the plugs to start with so it spins more quickly. Remove the relay for the fuel pump. Count 5 or 6 cycles with the key on and throttle wide open and then read the value quickly. Re-testing low holes is a good idea as the adapter may not seal well.
Absolute numbers vary with the pre-conditioning, gauge, battery and the technique. Do the first hole over again to see if the battery loss was making the numbers trend down.
Old Mar 1, 2013 | 06:16 PM
John Speake's Avatar
John Speake
Was the throttle wide open for the tests ?
Old Mar 1, 2013 | 06:29 PM
depami's Avatar
depami
As Glen and others have pointed out, consistency is more important than the numbers themselves.
Generally you don’t want more than 10% variation between highest and lowest cylinders. I’m not understanding the before/after meanings but compared to the others, #6 looks to be too low for sure. 160 – 10% = 142. I would test again ensuring 5 plus revs for the reading then do it again with an ounce or two off heavy oil added. If highest and lowest are within 10% of each other when tested wet, I’d think you should be good.
The WSM says 8 bar or more new, 6.5 bar wear limit. That is 116 PSI or more new, 94 PSI wear limit.
And as John points out, the throttle should be wide open during test.
Old Mar 1, 2013 | 08:19 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
+1^^^^ and a fully charged battery. Also, remove all the spark plugs. I think it should be done with a cold engine but a leakdown test would be much better.
Old Mar 1, 2013 | 08:35 PM
Hilton's Avatar
Hilton
Also it needs to crank over around 7 times per cylinder to for the tester needle to stabilise in my experience.
I have two testers - one gives 170-180 and the other gives 190-200 results, on the same car. So as noted above, worry more about variation between cylinders than absolute numbers.
The absolute pressure can be affected by pinholes, cracked o-rings, loose seals etc. on the tester - its not like they're highly-calibrated tools
Old Mar 1, 2013 | 09:59 PM
EMan 928's Avatar
EMan 928
Thanks for the feedback everyone. No, I don't believe the throttle was wide open for the tests. I may end up buying my own compression tester and do it myself next time. Right now I think I'm going to put some sea foam in the fuel and see if I can burn a little carbon...there was some present when we scoped it. Then, a leak down test.
Old Mar 1, 2013 | 10:04 PM
depami's Avatar
depami
What is the issue that led you to a compression test?
