HEAD LIGHT ADJUSTMENT
Yes, this was the problem to have the lights loose. The spring has gotten weak so a new one was needed. Problem solved but replace that plastic part too..
My headlights have a slight east/west wiggle and the gap on part #30 is wider than others.
Wonder if that part has 'adjustable' width or more likely broken and needs replaced?
Rather not dig into it if I need to source a replacement first.
I found this old post and the diagram is very helpful but can anyone point out the forward/back adjusting bolt in the pic.
Is it number 15?
Is it number 15?
In post number 7 MainePorsche explains this. If you look at the photo in that post the bolts are under the guard to the right of the east west adjustment bolts. You will probably need a torch to see them.
Thanks again GP found those and its all good now with everything centralised nicely.
I just need to fix the plastic headlight surround because when it jammed up on it one of the screws pulled thru
