16v Euro 84-86 performance EPROMs
#47
Just took on a 84 Euro project and am wondering if you have any chip mods for this MY Euro? I also have a donor 86.5 32V if any of it's computer parts are interchangeable (saw something like that above). Just getting back into the deep end of the shark tank... VERY deep end
#48
You use my chips with your 86.5 32v LH ECU as they are compatible.
It just the '84 Euro LH with part number 928 618 123 00 that is not compatible with my LH performance chip.
You can use any version of the EZ-F with my EZ-F chip.
Just took on a 84 Euro project and am wondering if you have any chip mods for this MY Euro? I also have a donor 86.5 32V if any of it's computer parts are interchangeable (saw something like that above). Just getting back into the deep end of the shark tank... VERY deep end ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
#49
John,
Thank you for the prompt reply. Two questions: What are the final performance #s with / without the chip set? I already have 86.5 exhaust manifolds fitted to a custom SS "Y" pipe and SS exhaust so she can BREATHE!!! What else would I need to accommodate the chip set?
Joel
Joel
#50
The before and after figures are shown here:
http://www.jdsporsche.com/16v%20perf...%20EPROMS.html
Your other mods will help things along but the chips can handle those.
Make sure the MAF is good, and idle CO set to 1% with air pump connected.
Since I developed these chips I have fitted a set of Type 2 4 hole injectors using Greg's adaptors.
There are also an improvement according to my butt although I haven't re-dynode the car since.
John,
Joel
Joel
#51
Thanks. I'll be in touch once I'm sure everything else is operating as designed.
Joel
Joel
#53
Seats, steering wheel, pod, dash, doors, windows, locks, trim, interior EVERYTHING, headlights, motor mounts, steering rack, exhaust manifolds/Y pipe/tail pipe/muffler... I'm sure I've forgotten more than I've listed... It's one helluva heavy lift for a "non-mechanic" like me... When are you and Sheldon coming back to Ohio?!?! ![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#54
Has there been more testing/successful reporting about these EPROMs from fellows who installed and ran with?
Might be interested in fitting a set on mine.
Ralph
Euro '84 manual
Ralph
Euro '84 manual
#55
84dizzy (09-25-2023)
#57
84dizzy (09-26-2023)
