Fuel Hoses NLA
Fuel Hoses NLA
Does anyone have the following that I could purchase:
(1) 928 356 081 02 feed line (should be return hose to fuel cooler.)
(1) 928 356 079 00 fuel hose (should be supply line to engine.)
(2) 928 110 359 00 bent line
Thanks!!
Thanks!!
Vegas, Baby!
Contact Mark Anderson@ 928 International.
Basic Site Sponsor
Basic Site Sponsor
That last part number escapes me. Description? Year?
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Basic Sponsor
928 110 359 00 is bulk hose and you could use Porsche or EFI (maybe). The actual part number is not available but the bulk hose is.
What Greg said on the other two.
Basic Site Sponsor
Basic Site Sponsor
Administrator - "Tyson"
OK I understand the need to replace the 20 plus year old fuel lines w/ new, but what do you do when you have a Concourse grade car w/ 24 k documented original miles and want to enter it in Full competition?
What options do you have for fuel line replacement?
Thank you,
Dave
Thank you,
Dave
Thank you,
Dave
Thank you,
Dave
Myles
Basic Site Sponsor
Basic Site Sponsor
Thank you,
Dave
Thank you,
Dave
I make a replacement pressure line that runs from the fuel line on the right side of the engine compartment to the front damper, which "blends" in pretty darn well....but I can also weld a fitting onto that stock metal line and have it re-plated. There is then a very short hose that replaces the short piece of plastic line, at the very end of this metal pipe. I do this for the "Concourse" later model cars.
The rear fuel line that runs from the rear damper to the regulator doesn't ever show. I make a line for that out of "bullet proof" stuff. That hose is originally plastic and is now "brittle" plastic. The rubber hose that runs from the fuel pressure regulator to that strange adaptor that is bolted to the rear of the block can be replaced with the above mentioned N020 281 1 and two hose clamps (just like it was originally.....I'm hoping that someone has already changed this rubber) I then make a replacement hose that runs from that strange adaptor to the fuel cooler (which was also plastic hose originally and is also now "brittle" plastic.)
Don't mean to hijack here but Greg, do you have a 10mm hard line compression fitting to -AN adapter or can you source it? It would be for power steering lines.
Auto Atlanta has your 1st hose listed (about $48)...the second and third show not available if shopping for 87's and newer. The second hose was showing available for 86's.
I just purchased 928 110 269 01 for my 87 S4 from them -- nice, original hose.
http://www.autoatlanta.com/porsche-parts/928.php
Mike (no affiliation)
