928 Forum 1978-1995
Sponsored by: 928 Specialists
One Cooling Fan Non-Operational
Old Mar 6, 2013 | 02:17 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Hans is parting out an 87 - does that help?
Old Mar 6, 2013 | 03:08 PM
Speedtoys's Avatar
Speedtoys
Originally Posted by Randy V
Turns out it is the Output Fan module, PN 928 618 421 00.
This unit is NLA, although 928 International sells a rebuilt unit - and they're not cheap.
Our Greg B. is the one who rebuilds them. My unit has not been molested so it's good for a $200 core refund.
Randy:
Im still at least 2.5 weeks away from seeing my car again..but when I do, was the module determined to be at fault via the WSM procedure?
Old Mar 6, 2013 | 03:42 PM
Randy V's Avatar
Randy V
25 Year Member
Originally Posted by Speedtoys
Randy:
My mechanic troubleshot it, starting with fuses and relays and working out from there to discover it was the control module.
He also discovered that the other fan is also not operating correctly - it goes from off to the high speed setting, bypassing the low speed setting. Another indication of a failed controller module.
Old Mar 6, 2013 | 05:40 PM
Tom in Austin's Avatar
Tom in Austin
I wonder about mine because it has never run more than a couple seconds after turning off the ignition ... even on very hot days using the A/C. My 968's fan would run for a while under these conditions.
I just go by the gauge and haven't seen any concerning readings, but suspect the system may not be 100% ...
Old Mar 6, 2013 | 06:01 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
The late 928s do not run the cooling fans after the engine is shut off. All of the 4 cylinder cars did. Note that the 928 windshield washer tank holds more fluid than the entire cooling system of the 4 cyliner cars....
Alan's Avatar
Alan
Electron Wrangler
Tom,
Remove the connection to the temp switch right on top of the intake - short the two wire connections together - then see if the car after-runs. If yes you have a failed thermo switch - easy to replace.
The only other thing that might cause the fan to stop is if it thinks the hood is open - does your hood switch cause the underhood light to go on? This interlock is so the fan can't start up unexpectedly when you have your hand around the area of the blades.
Alan
Old Mar 6, 2013 | 06:02 PM
Alan's Avatar
Alan
Electron Wrangler
Greg - GTS cars do run the fans after the engine is off if the intake is hot enough...
Alan
Old Mar 6, 2013 | 06:18 PM
Randy V's Avatar
Randy V
25 Year Member
Correct - mine does.
Old Mar 6, 2013 | 06:34 PM
jWs-928's Avatar
jWs-928
check the fuses as Herman says - then swap the fan connectors and see what happens. If that fan works and the other stops - its the controller, if the same fan is dead its probably just the motor on that fan (brushes worn out or burned out winding maybe...)
Alan
If the above scenario is true for you, as it was for me (same fan dead after switching connectors), you can try tapping lightly on the the fan motor housing with a hammer....
...per my father's suggestion, i tried this and it worked like a champ....so far so good...
Old Mar 6, 2013 | 06:41 PM
Alan's Avatar
Alan
Electron Wrangler
I think its obvious this isn't likely a good long term fix - but probably indicates a brush wear/commutator issue - that can likely be repaired with new brushes and/or a little cleaning.
Alan
Old Mar 6, 2013 | 06:42 PM
Leon Speed's Avatar
Leon Speed
You must have really long arms
Old Mar 6, 2013 | 06:48 PM
jWs-928's Avatar
jWs-928
yes, OBVIOUSLY not a long term fix...
Old Mar 6, 2013 | 11:30 PM
pcar928fan's Avatar
pcar928fan
These controllers are dropping like flies! My '95 had a dead controller! DOH! After I priced it out I nearly fell out of my wheelchair!!!!
Old May 15, 2013 | 01:12 PM
AWasserman's Avatar
AWasserman
Default Just checking...
I would like to try the switching wiring diagnostic.
Does anyone have advice on how to go about this?
Better from up top, or from underneath?
I guess the wiring harnesses will extend far enough in either direction? It does not really look like that to me but maybe if I pull them out of their routing channels?
All help appreciated.
Adam
Old May 15, 2013 | 04:02 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Adam
Easiest access to the plugs is from below assuming bellypan is off/missing. Otherwise they can be reached from above but a lot of stuff obscures the view and reach. You will have to clip a few wire ties and/or remove a part of each harness from wire clips on the shroud to get enough slack to do the swap.
