928 Forum 1978-1995
Sponsored by: 928 Specialists
After a year of searching, finally found my 928
Old 03-02-2013, 06:30 PM
bigcatindallas
bigcatindallas's Avatar
Default After a year of searching, finally found my 928
In cars, as in life, it pays to be patient. I have looked at most 928s available from Texas to Canada over the past year, hoping to find the perfect one for me.
Just as I had almost decided to slow down my pursuit.....I found her only a couple of hours away in Weatherford TX. After I saw the price, and the pics, I drove there as fast as I could and snapped her up. I even broke a promise I had made to myself to not buy a car I had only seen in the dark.
About my car:
1980 Euro Auto 130k
Black on Black
2 owners, this guy had it 13 years
Interior is immaculate besides some wear in the seats
Paint is great
Runs like a top
only very minor issues
Thanks to all of you who heped me in my search!
Looking forward to joinig the DFW group very soon
Mike
Old 03-02-2013, 06:31 PM
bronto
bronto's Avatar
The thread...
Old 03-02-2013, 06:36 PM
Randy V
Randy V's Avatar
What's up with that window trim?
Is it missing the rub strip on the front fender?
Congrats on joining la famiglia.
Old 03-02-2013, 06:54 PM
bigcatindallas
not sure on the rub strip....the driver side is there.
Old 03-02-2013, 07:06 PM
Jim M.
Jim M.'s Avatar
Yeah, the RH front section of the rub strip is missing. Most likly means the fender was changed during it's life, because there should be two holes IIRC.
Now you need to join the DFW crew on our monthly breakfast GTG's. Contact Roger (see link in my signiture) and he will add you to our mailing list. We have several 928's in and around McKinney.
Old 03-02-2013, 07:49 PM
bigcatindallas
yep...sounds logical on the fender.
Have been to Rogers place a couple of times...he was helping me look.
Also need to talk to Sean or someone else about hiring him for an hour or 2 for a tutorial. I am having a horn issue....may just need a relay, but need it to pass inspection
Old 03-02-2013, 07:55 PM
rgs944
rgs944's Avatar
Congradulations.
Old 03-02-2013, 08:05 PM
jbrob007
jbrob007's Avatar
Congratulations! Glad you found the car of your dreams! Now make it your own and drive it like ya stole it!!!
Old 03-02-2013, 08:36 PM
linderpat
linderpat's Avatar
Received 2,324 Likes on 1,277 Posts
welcome to the shark tank. More pictures please!
Old 03-02-2013, 08:42 PM
Jim M.
Jim M.'s Avatar
Also need to talk to Sean or someone else about firig him for an hour or 2 for a tutorial. I am having a horn issue....may just need a relay, but need it to pass inspection
Horns are located in the RH front wheel well. Remove the WW liner and check for voltage when someone presses horn pad. The horns are a common problem, they get full of water and rust solid. If you have voltage replace the horn.
Old 03-02-2013, 09:42 PM
CJ8 2 928
CJ8 2 928's Avatar
Welcome to the tank. I saw that car this morning on C/L but never got around to calling. If you need any parts Richard up in Leonard has several OB's .
Old 03-02-2013, 10:15 PM
bigcatindallas
starting to make sense....right fender looks like it has been replaced and that is where the horns are located. Probably not a coincidence. Thanks guys
Old 03-02-2013, 11:09 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,434 Likes on 1,365 Posts
great looking car, you will have fun with this one.
if your going to keep the wheels you have,
might I suggest to measure from the outer edge of the rear tire to the inner edge of the fender subtract 5mm that is the clearance you have to work with,
then get some bolt on bolt on spacers as close to your measurement without going over,
This to kick the rear wheels out,
the reason they are sucked in is to make room for tire chains
Old 03-02-2013, 11:11 PM
Hilton
Hilton's Avatar
That would explain why it looks like a USA car in the pic, with no Euro side markets just in front of the door shutline.
Welcome to the tank
Old 03-03-2013, 08:28 AM
Dave928S
Dave928S's Avatar
Welcome! ... congrats on your purchase.
Quick Reply: After a year of searching, finally found my 928
