Our 6-speed Project
#197
Developer
I found this on-line:
All factory C5's with the manual transmission came with the 3.42 axle ratio, there was no other option available. But the A4 equipped models had two choices of axle ratios. The standard equipment was the 2.73. An optional "performance ratio" G92 was available as an option; this being a 3.15 ratio.
Here is where I found that info:
http://www.tim-yvonne.com/mikemercury/ratio.htm
Mine is a 3.42 FDR
Mine is a 3.42 FDR
#198
Developer
Just a progress note: the torque tube is at the welder getting the finished welds on it, and we have some new (improved) driveshaft couplers supposed to be here tomorrow. Then we can put up the exhaust and take it for a drive!
Here's a pic showing the stock Corvette shifter in its final location in the 928 center console.
#201
Developer
That question has already been discussed in this thread. Page 12 and 13.
So far, it looks good but I am a little worried about the one crossover behind the differential made by the aftermarket performance exhaust by Motorsport. The stock exhaust will be no problem.
Hope to be putting the exhaust up in the next week or so, then we will have our final answer.
#202
Developer
Some new pics of the near-finished kit.
Here is the finished torque-tube (Chevy on one end and Porsche on the other); the driveshaft complete with bearing, upgraded couplers and splined Porsche stub shaft; the custom shifter linkage, and the 3-piece rear cross-member. The black section in the center is made from Chrome-moly steel and we have both solid and polyurethane trans mounts for it. Note also the shifter box located on the torque tube in the correct 928 position. You can use the stock or any after-market 'vette shifter.
Not shown: the two custom half-axles and the hardware.
#203
Very cool. A couple of questions:
Any ballpark ideas on what the kit will cost (with and without installation)?
Any thoughts on whether it would be possible to convert a Rogerbox 928 to manual using this kit? If so, what to do you think that would involve and cost?
#204
Developer
I think it will be coming to market at $5300. The 928 owner is responsible for acquiring his own C5 ZO6 transaxle, TT, driveshaft, shifter linkage and shift box. My customers and I are locating good used ones for between $1500 and $2000.
The transaxle doesn't need to come here. But the TT, driveshaft, shifter box and linkage do so we can modify them for you.
So: My price is $5300. Full price to the consumer (if he pays $1800 for the used parts) is $7100.
We will install it for $1400, or you can install it locally.
I have no experience or knowledge of a "Rogerbox 928" so can't comment or guess on what that conversion would be.
#205
Administrator - "Tyson"
To answer the question, you need to install a master cylinder to the firewall. The automatics do not have a provision for this. The best way to do this conversion is taking out the engine, and welding in a master cylinder portion from the firewall of a donor 5-speed car.
Another option is to use an aftermarket pedal assembly with it's own master cylinder and fluid reservoir. Colon (aka Lizard) did this to his car.
#207
Developer
On this page: http://www.928motorsports.com/parts/...pgrade_kit.php
I mention using our kit to facilitate the auto-to-manual conversion this way:
See post #166 on page 12 of this thread for a picture and description of what parts you need.
Automatic-to-Manual Conversions: This kit can also be used to convert a 928 with automatic transaxle into a manual trans car. One of the largest expenses of such a swap has always been finding and acquiring a good used Porsche 928 transaxle. You also need the 928 torque tube, flywheel, clutch assembly, bell housing, and pedal assembly. Good used Corvette 6-speed transaxles are much more plentiful and less expensive (and more fun!). With the parts we supply in this kit, the actual 928 items you need to buy to finish the swap is limited to only the clutch and clutch pedal systems.
#208
Developer
What the driveshaft looks like without the torque tube. Here you see the end of the Corvette driveshaft, the isolation coupler, then the 928MS splined input adapter with the heavy-duty driveshaft bearing mounted, then the stock sliding coupler and stub shaft entering in to the stock pilot bearing.
#209
Developer
6-speed kit update: Just proofing the final pieces (I didn't like the parking brake design I had so I am making another, better one) then I can continue with the scale-up from these prototype pieces to a production quantity of each part. I have enough rear cross-members to make 4 kits right now.
Work on this kit is interrupted right now by Speed Week at Bonneville. I will be back at it on Friday the 15th.
#210
[QUOTE=Carl Fausett;11556098]6-speed kit update: Just proofing the final pieces (I didn't like the parking brake design I had so I am making another, better one) then I can continue with the scale-up from these prototype pieces to a production quantity of each part. I have enough rear cross-members to make 4 kits right now.
Work on this kit is interrupted right now by Speed Week at Bonneville. I will be back at it on Friday the 15th.[/QUOTE Carl, your transaxle kit is amazing. What trans will you be running at Bonneville? Good luck! Drive fast, take chances. Dinsdale Piranha
