Alternator Hose
#31
Second update. The hole in the bracket is loose on an M3 bolt; an M4 could probably be made to fit.
It also seems to me that the spire nut would fit directly on the hose bracket and not on the splash shield itself.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
#32
Third update: Rob previously posted about wheel well hardware and he also mentions the alternator bracket hardware sizing. I didn't realize that he had previously mentioned it until late yesterday. https://rennlist.com/forums/928-foru...-hardware.html
Additionally, I chatted with Jadz and he advised that a No 8 x 1/2" pan head Phillips screw with a No 8 x 1/2" OD washer would also work for the alternator bracket.
I thought I'd post these findings here in case anyone is ever searching for the same info.
#33
I'm curious. What does that sensor Do? How long is this hose? I have to change this hose since its grimy and oily.
#34
The sensor is for external air temp as part of the climate control A/C. If its not connected and working, you can only get full cold or full hot, nothing in between.You need around 3 ft of hose. Check my link above about attaching the hose without using the splash shield - much easier to R&R the shield later, and wont damage it.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
#35
Electron Wrangler
IMHO attaching the hose to the splash shield was one of Porsche's stupider moves. It makes no sense - it is difficult to both assemble & disassemble and is not a long term secure connection for the hose and requires the hose be left longer than necessary. Attaching solidly to the fender support bar is how this should have been done. I have no qualms improving over these clearly stupid things Porsche did.
There is lots of really nice engineering on these cars - then there is crap like this implemented by those "Engineering B-Team Losers" (e.g. the hatch release motor, door release handle hinges, early headlight aiming mechanism, early electric motor door actuators, window switches, pod illumination, interior light fixtures, S4+: fog light & driving light aim adjusters, gas cap pawl... more). These need to all be fixed properly - else you will be living with their failure AND fixing them again and again and again...
Authenticity can be a giant pain in the *** - I'm over that for all these crap things whenever that is possible...
Alan
Alan
