928 Forum 1978-1995
Sponsored by: 928 Specialists
Drivers side cam gear
Old Feb 3, 2013 | 11:56 PM
supercedar's Avatar
supercedar
Default Drivers side cam gear
Are the cam gears available ? I need a driver side if anyone has one.
File Type: png
Old Feb 3, 2013 | 11:57 PM
Speedtoys's Avatar
Speedtoys
Call roger, he has the new sexy, and cheap.
Old Feb 4, 2013 | 12:00 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
if you can get them both ,
also a new oil pump gear,
and the crank drive gear if its worn
Old Feb 4, 2013 | 12:10 AM
supercedar's Avatar
supercedar
Thanks for the great news Jeff, I thought we were still waiting for these. I will get with Roger in the AM.
Stan,
I will only need the drivers side as the PS has all the coating on it. Are you thinking I should get both because new manufacturer now?
I will get the new steel oil pump gear (and remove the spacer) and the crank gear. Thanks for all your help today.
Thomas
Old Feb 4, 2013 | 12:26 AM
Lizard928's Avatar
Lizard928
Replace the cam gears in sets!
And yes Rogers are manufactured much better than the stock ones
Old Feb 4, 2013 | 11:27 AM
SeanR's Avatar
SeanR
I'm a fan.
Old Feb 4, 2013 | 11:42 AM
supercedar's Avatar
supercedar
Good timing Roger is expecting them today or tomorrow. All the gears are getting replaced.
Thomas
Old Feb 4, 2013 | 11:51 AM
Ducman82's Avatar
Ducman82
Veteran: Air Force
i would get Rogers set too. crank gear should be ok, being it is steel.... but id check anyway...
Old Feb 4, 2013 | 01:15 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
yes this is a great idea to swap in new sets of the driven pulleys
Old Feb 4, 2013 | 05:14 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
Actually, both the oil pump and the crankshaft gear wear also. Porsche, of course, superceeded the oil pump gear to a steel one, because of the high wear rate of the original aluminum one.
Many people fail to pay any attention to the crank gear, but since it turns twice as much as the cam gears, it usually has significant wear, even though it is steel.
If you fail to replace this gear, it "transfers" it's wear pattern into the new belt, which transfers that wear to the new cam gears. The belt is only going to be as good as the surface it touches.
An "original belt" frequently would last 60,000 miles from the factory. The 1st replacement belts would usually "make it" about 45,000 miles. The 2nd replacement belts frequently would not last 30,000 miles.....all because of the accelerated wear from worn gears.
Old Feb 4, 2013 | 05:19 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
most of the higher mile belt jobs I do also include a new crank driven gear,
to check it put a straight edge on the top of the tooth and see if its flat front to back,
if its cupped then a new gear should be installed
Old Feb 4, 2013 | 06:04 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
Exactly what I do, also.
Attempting to pass that knowledge/proceedure on to the the "home" guys here.
Good to give them a visual way of checking!
