Tire Size
depends on the wheels you are planning to use.
For sure you cannot mount 285's on the same wheels you currently have the 235's.
for 285 I think you will need at least a 10 inch wide wheel.
The height will just fit I think, but 285/30/18 would be better.
A 235 on the rear-ow did that happen? Must be like driving on a bar of soap.
There is a limited size width range that a given width can be fitted on and the range is more limited the lower the profile. The Tirewarehouse website gives you such data for specific tires/makes- I always refer the Michelin pages.
For 285 x18 tire you will need rims in the width range of 9.5 inch to 11 inch I suspect. 10 inch is optimal and you should go for a 285x30 section as this is nearly identical to the stock rolling radius.
If a 235 fits your current rims then a 285 will not I would think.
Fred
Fred
I currently run 275/35/18 and the wheels are 10 inch... barely fit under the lip... might take off some paint with 285... In addition, 285/30 wont leave much cushion left for pot holes, etc...
I run 285/30 18 on the back... have plenty of room inside and out... and run w/ 5mm spacer.
CLW's 65 ET and Pirelli tires
Btw There are other posts on this subject and I think there's even a calculator
