Mann Pro Vent seperator
Who has the best price on this unit? I don`t need the entire 928Spec. kit as I can`t mount it up front/middle. Just the cannister portion. Thanks. Kevin
Archive Gatekeeper
The 200 will do fine unless yo have a lot of blowby I guess. There is a 400 series, goes to 500 HP. The 800 goes to 1250 HP. The 400 is IIRC 160 mm in diameter, might not fit in front of the engine. The 200 series is about 110 mm.
Archive Gatekeeper
Yep, there's a 400 and an 800, challenge is to fit them somewhere in the car:
https://www.mann-hummel.com/fileadmi...ProVent_en.pdf
I have the 200 and it flows just fine at 370 rwhp. I messed around with other options for venting and this is hands down the best. I set it up to drain the separated oil back to the pan. My car uses very little oil, maybe have to add 1/2 qt between changes.
Inventor
Search for 3931070550.
$117.16 - http://www.diesel-filters.com/393107...l-off-highway/
(Haven't ordered there, myself.)
Archive Gatekeeper
Woo, knew I shouldn'ta written that.
Good price!
