928 Forum 1978-1995
Sponsored by: 928 Specialists
Better alternator option
Old Mar 16, 2013 | 10:29 AM
  #61
Ducman82's Avatar
Ducman82
Veteran: Air Force
just ask for a reg from a f150 v8. slap that sucker in ..
Old Mar 16, 2013 | 02:49 PM
  #62
LT Texan's Avatar
LT Texan
25 Year Member
Thanks Ducman. For the advice and for keeping your awesome avatar.
Old Mar 17, 2013 | 03:11 PM
  #63
JHowell37's Avatar
JHowell37
I believe the regulator I bought was from a '96 crown vic. It might also be from a '96/'97 F150. A lot of their cars used used that regulator on the 3G alternator back then.
Old Mar 17, 2013 | 03:30 PM
  #64
Alan's Avatar
Alan
Electron Wrangler
Originally Posted by CraigL
...I think it is fair to say that very little is known about the function of the ext temp sensor in the disconnected hose....
I have no idea why you would say this...? We know exactly what it does and it has nothing to do with the alternator... It is part of the temperature sensor loop for the HVAC. While moving air gives a more accurate reading more quickly on start-up - its an ambient temp sensor so it will work adequately in free air in the same location - just will cool down more slowly when you have been parked in hot ambient conditions. As long as you are moving creating airflow it will work fine, stopped in traffic it may also heat up above ambient. Since in that case it will temporarily enhance cooling I'm not sure that matters so much. If there is no airflow in the duct - remove the sensor from the duct...
The ext temp sensor is a secondary sensor - the in cabin sensor is primary. The temperature set on the slider and the primary sensor/cabin sensor determine most of the mixing flap position. The secondary external sensor modulates this only slightly. If its cold out it mixes warmer to compensate for environmental chilling and colder air intake, if its hot out it modulates colder to compensate for environmental heating and hotter air intake.
Alan
Old May 21, 2013 | 06:15 PM
  #65
U-928's Avatar
U-928
As I'm I the process of doing this swap as well I thought the following may be of use to anyone else considering the swap.
I chose to use a $40 used alternator for the initial swap, and when/if the one fails, I'll buy a new one. The contour alternator as it came to me, with this regulator:
And the brand new Motorcraft genuine '97 Crown Vic V8 (didn't matter vin#-wise, they all use this regulator)
The new regulator comes with new brushes attached, which I'l be removing and swapping with the ones originally from this used alternator. Doing this so that when/if I swap to a new alternator, ill have matching new brushes. Also wont have to worry about the new brushes wearing into the grooves left by the original brushes.
Came with a nice 12" section of the alternator harness as well. With a sweet cover for the B+ terminal.
Old May 21, 2013 | 07:09 PM
  #66
CraigL's Avatar
CraigL
Poor choice of words. No one seemed to know how the climate control function would function if the hose was disconnected. I'm sure there are thousands of vehicles with that 'feature' but little is written about it. Thanks for the info.
Old May 21, 2013 | 10:30 PM
  #67
supercedar's Avatar
supercedar
Since the thread title is A better Alternator Option here is mine for now.
I bought a rebuit 928 from O'Reilly Auto parts for $129.00 with a lifetime warranty. They also charged me a $54.00 core which I elected to pay to keep my original Bosch in my possession.
I first tried the regulator replacement which did not cure my problem.
Thomas
Old May 21, 2013 | 10:37 PM
  #68
JHowell37's Avatar
JHowell37
Just so you know, you can get a brand new pigtail from most parts stores for only a few dollars. I would reuse the plug with the single wire attached, but I'd replace the rest since it's not that expensive.
As for the brushes, you might as well stick with the new ones. If you get a new or rebuilt alternator at some point, it too will come with new brushes, so it's not like you have to save them for anything. And having the new brushes conform to the existing slip rings is not a big deal. It happens within a few miles of putting them in.
Old May 21, 2013 | 10:54 PM
  #69
Landseer's Avatar
Landseer
Finding this alt swap is a big win for all of us with the 32V cars.
As you know, I drive mine, often long distances.
Knowing a replacement alternator exists anywhere in the country is peace of mind.
BTW, have 6 years on a pair of Delcos now (earlier cars)
Old May 22, 2013 | 07:35 PM
  #70
U-928's Avatar
U-928
I'm finding, now that I have my car up, and apart and comparing the two, that this is not as "direct" a swap as I was initially thinking it was.
So we're all on the same page, my car is a US spec '82 4.5L.
Some things:
On my '82 model, you can see that the crank pulley configuration is not the same as JHowells. His alternator drive is off a much wider ribbed pulley off the very front of the crank.
Mine is off a 4-ribbed belt, second pulley in, behind the v-belt drive for the p/s.
I don't know what the upper "boss" on the block looks like on Howells, but on mine there is a gap between the [threaded] block section and the bolted on bracket that supports the p/s pump. A difference between 16 and 32V blocks or the brackets? IDK.
Consequently, the alternators look considerably different. For consistency; Porsche on right, Ford on left.
Pulley sizes aren't that far off, measured from the "high" spots on the ribs, the Ford measures 54mm dia. and the Porsche is 52mm dia. 6-rib vs. 4-rib.
I'm not even sure just swapping to the same style crank pulley would make this work without better pictures of the differences of 16V vs 32V mounting locations.
Needless to say, my fussy low-volt-and-amperage-outputting factory alternator is going back in. Bummer. It's annoying having your radio cut out when your radiator fans kick on.
Old May 22, 2013 | 08:58 PM
  #71
Landseer's Avatar
Landseer
Why are you performing a late model swap on an early model car?
Delco swap is what will work for an 82.
This Ford swap is appropriate for the 32V cars.
Old May 22, 2013 | 09:47 PM
  #72
U-928's Avatar
U-928
Wasn't even aware there was another swap! No one in this thread mentions this is for 32V only anywhere, maybe the thread title should be changed to include such important information for future reference.
Anyone want all the parts to do this swap since apparently I don't need hem now!?
Haha what the hell......
Old May 22, 2013 | 11:00 PM
  #73
Landseer's Avatar
Landseer
I mentioned it, though, at posts 5 and 69.
Obviously not clearly enough.
Jason needs to augment the title a bit. His car is an 85, but you don't know that, either!
Anyway, the 88 Camaro 105A will work on your 82.
Old May 23, 2013 | 01:54 AM
  #74
Hilton's Avatar
Hilton
To clarify here.. are you saying the Delco CS130 alternator from the 88 V6 Camaro is a pretty easy replacement for the Paris-Rhone alternator on early cars? If so, is there a solution to refitting the shroud?
I helped pull a Paris-Rhone alt off a friend's car last weekend and he's looking for replacement alternator suggestions..
https://rennlist.com/forums/928-foru...lternator.html
(for reference, his car is an '83 "Euro S" 16V CIS car - has a paris-rhone with 4-rib belt).
Old May 23, 2013 | 04:21 AM
  #75
Landseer's Avatar
Landseer
Easy swap if you are ok with eliminating the shroud.
Have replaced Paris Rhone with Camaro unit on two 84 cars.
Requires an appropriate pigtail.
