'89 S4 Display Reboots On Start-Up
My '89 S4 has the digital dash reboot every time I start the car -- any ideas? The firmware version shows up, then I have to reset the computer to stop showing fuel mileage.
Thanks!
-Robert
Thanks!
-Robert
Electron Wrangler
Your battery voltage is dropping too low during starting - charge it up better & check your alternator output or just get a new battery.
Alan
Alan
If the battery is good and the terminals are clean, then you might check the ground strap to the battery. Even if it looks good on the outside as it can still be corroded internally. My '89 had the same symptoms (and with new battery too); ground strap looked great, but was bad. A simple search will turn up plenty of information about this problem. HTH.
Bob
Bob
This was happening to me as well.
Really cold weather (At least for us in DFW) this year. i usually run the GTS every weekend, but the digital dash would run to ---- every week. I ordered a new ground strap from Roger and it has been fine ever since...
I didn't think about it until Sean replaced Richard (Stretch) James' ground strap. Stretch's car would NOT start after sitting for more than a few days. Sean replaced the ground strap on his car and it's been fine ever since. Sean has had the car for a while doing some PM on it and the car sat for 3 weeks. Started up fine after 3 weeks.
(I'm sure Sean will post some pics)
I'll post a few pics, but if memory serves me, it was the one that Rob Edwards or Dr. Bob found.
New cable and shrink wrap is about $20-$30 less than a factory replacement. Mine looked "OK", but I guess it wasn't...
It cured Stretch's car, helped mine retain "outside temp", so if you're having a problem, the ground strap may be the culprit, or at least part of it.
Here's one of the posts I came across:
https://rennlist.com/forums/928-foru...ps-are-in.html
Post #27 was Stretch's car. It was jacked. Now wonder she woulnt't start after a few days..
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
This was happening for me in my 89 car, but it was a loose fuse for the interior light. (Same circuit) I had to bend the pins on the fuse a bit to make better contact. All works perfect now.
