928 Forum 1978-1995
Sponsored by: 928 Specialists
Random loss of all electrical power
Old 09-25-2013 | 08:29 PM
  #76
MainePorsche's Avatar
MainePorsche
Originally Posted by MainePorsche
... I would examine/detach/inspect the major lines from battery, starter, and alternator...
Originally Posted by Jim Devine
Any chance the positive battery cable is corroded
under the insulation at the battery terminal end
(like what happens to the ground straps)?
Might be worth opening it up to have a look. If
nothing else, it would eliminate another possibility.
Originally Posted by Alan
...You could also strip back the sheathing from the ends (start battery end on Bat/Starter cable) and see if its heavily corroded (my guess is right there if you get this far).. If its not these then you can use HD heat shrink tube to repair the ends.
Alan
Originally Posted by G8RB8
I think you're going to find a loose or corroded connection at the starter positive post.
Yes I'd have been looking there too...
Alan
I thought this was already inspected, and cleared.
Old 09-25-2013 | 09:30 PM
  #77
G8RB8's Avatar
G8RB8
I don't think corrosion or mechanical failure inside the terminal ends has been investigated sufficiently.
Old 09-25-2013 | 09:43 PM
  #78
Bill Ball's Avatar
Bill Ball
Under the Lift
Sure, maybe not. I did take off all the connections, clean the lugs and posts, wiggle everything quite a bit before and after I put them together, but this was awhile ago before the specific comments about the crimps themselves. So, I may not have been thorough enough. I'm going back in there next week.
Old 09-25-2013 | 10:06 PM
  #79
neilh's Avatar
neilh
Bill, these crimps are 25 + years old, please home in on them - run a bypass cable ( one side of a jump set even) and see what happens. I have a back up test cable i use any time i suspect a bad battery to starter or jump post, just because !
Quick Reply: Random loss of all electrical power
