HELP WITH A STRANGE VIN NUMBER
I am thinking about purchasing a EURO 928 which the owner says is a 1978. All of the research I seem to be able to do is stating the VIN is a 1980. Can someone give me a definitive on the VIN?
I did verify that I have the VIN correct as I have a picture of the VIN. Is there anyone that is versed in pre 81 928 VINS?
It is 928 106 023 15
Your help is Hugely appreciated.
Tim
Tim
Inventor
Radiator part number.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Sure, but is it a 78 or 80 radiator?
1978 928 VIN Range - 9288200001 - 1139
1980 928 VIN Range - 92A0810011 - 1649
Look on the fender just under the edge of the hood towards the rear, or the driver door jam.
When I put that number into an online VIN database tool it comes back as a 1980 928 EURO 4.5 litre.
VERY STRANGE....
![nono](https://rennlist.com/forums/graemlins/nono.gif)
At some point in its life, somebody at a motor vehicle registration place probably was given or pulled the numbers from the top of the radiator. Here is a pic of an early radiator.
Talk to you local DMV regarding the title mess. The VIN should be stamped on the passenger side fender under the hood about where the washer fluid bottle is located.
Correct stamped into a flat spot readable from under the fender....Getting it "corrected"depends on the DMV you have to deal with.....and what they think of grey market cars
Where are you located (state), assuming USA?
If its a Euro, there exist import records that can be tapped to solve.
May be a VIN plate in engine compartment near hood latch.
Pictures would help.
Did you buy or are you considering buying?
