Sub 2 mins at T-hill at what cost?
Everyone......don't be fooled by the BIG HP bandwagon......yes it is important, but it is by far the least important part of a racecar.....handling is #1, weight, balance, braking are far more important that power alone....
Casper is quite light...& there is more room to go lighter....possibly 2550lbs with some extreme measures... Casper also is surprisningly NOT nose heavy....52.6% with me in the car and 1/2 tank....it is the fastest turning (think direction changing) race 928 I have ever driven..... Small steering wheel, solid steering rack bushings, hard A arm bushings and heim jointed suspension all contribute to this....
My opinions....my best is 2:02.12 right now with a 2:01.41 theoritical best....on USED slicks with NO aero at all.....Fresh slicks is probably a second easy.....aero is much more.... I am going out again the end of this month.....if the weather is decent we shall see... I think Casper at 300whp could break 2:00 over the top....for sure with aero....
I have my doubts about a "simple" SC system working well on a road course due to heat rise from the duty cycle without a full cool down between spurts.
Advantage of the Euro hybrid is that it can slip past some costs, with used 968 pistons you can do a cheap bore without Nikasil coating, just cost of rods and no "real" need for a stroker crank to make 350 rwhp, just a hotter cam, chips, and good exhaust. Something like $500 to bore the block, $300 for two sets of 4 968 pistons, $1600 for rods, $1100 for rewelded cams, $700 for lifters and 951 valve springs, $1k for exhaust, $500 gasket set, plus cost of the US and Euro basic parts, total looks around $10k. About $3k less if you skip the 104 bore, and maybe the rest would be sufficient?
howevrer, with 50 more HP you would get down a second for sure, but not much more. thunderhill is not really much of an aero track, but if you got it and actually use it, it can help in turn 8 and turn 1
your smoking the slick crack right now. put the DOTs back on and watch you go back to the 2:04s. (which is very fast by the way.)
Which leaves the other 2.3 miles with a lot of drag (add more HP) to manage.
I have just accurired the crank rods pistons etc for a 6.4L bottom end. I will be running the heads with 968 valves and modified S3 cams I purchased from Jim Morton several years ago and possibly the ITB set up I just bought from Mike Simard and a motec ECU This engine should make 550 Rwhp easily but that's a $ 15k motor min. Going in the new Widow.
I agree with danglerb that the euro 5.0L is the best value option I just bought a block from Mark a to build the bottom end. Eventually it will find its way into the # 52 car. My goal for the 52 is 2:00 min and under $ 10K
exactly. however, all that drag, might only be 5hp, but its 5 hp over the , probably more like 2.7miles. (3miles minus 100 yards of turn 1 and turn 8 and possiblly a little on the 65mph turn2)
To your point I have a supercharged 16v 475rwhp 1980 It would break 2:min easily at T-hill but would probabaly only run 4-5 laps before overheating. It would have comparable straight away speed to a cup car think 150 Mph before breaking for turn One. Fast as stink I tried to race it last season it was a huge headache dealing with the over heating issue.
I thnk the only one that might would be the 1000hp old mercury that races in GT1 with SCCA
where are you getting this $10k number when you already have $10k into the #52, or did you get into that car for CHEAP!!
Paid $ 5 k for the car.
Mark you telling me the cup cars can't hit 150 at T- hill? That's what they saw a the Edmonton Indy track which has a similar length straight and a lower entry speed.
I dont think anyone we know, with a cup car or top winning ITE, AV8SS, or even transam car, gets to 150mph into turn 1. ( or its very rare) cup cars, WCGT Vipers, etc, get to 140.
where are you getting this $10k number when you already have $10k into the #52, or did you get into that car for CHEAP!!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Brian you there?
150 is a pretty stout speed at thunderhill. check on mike hedman's cup car ,runing 1:51s . sure , its not the latest , but pretty new.
I just checked out the Winning 25 hr cup car video. Looks like Memo Gidly was close to red line in 6th at the end of the straight. So pretty quick! I think the rims on that thing were probabaly more than $10K definetely worth more than I paid for the 52 .
I think the fender rad is too small and I need better ducting to the engine main rad.
I can drive around town all day in 90Deg heat with no problem. I am having the problem under racing conditions and 90 Deg F ambient temps.
I like the power but the system is a pita and not a good idea for racing. In my opinion
http://www.facebook.com/Merc9Speed#!...type=2&theater
Here is the merc running with near 1000 hp. 150mph , and there is not many that can keep up on the straights. a brand new cup car, maybe, but it has to be a new one.
