Finally got around to a valve cover refresh
Almost Deleted
Valve covers on the 88' S4 were original [with original gaskets], so I finally had time to pull them off and rid myself of those dreaded valve cover oil leaks.
As expected, Dwayne's write-up was utilized in the process:
https://rennlist.com/forums/928-foru...-w-pics-3.html
passenger valve cover after paint:
Team Owner
what color white did you use?
That should look pretty cool.
I would suggest to use a thin bead of Hondabond 4 in the cover groove,
prior to installing the gasket into the cover.
Also make sure to fit the sealing washers under the heads of the cover bolts,
Roger has em
IIRC you need 26.
Oh a dab of HB4 to each cam cap joint where it meets the head surface prior to installing the cover
Roger has em
IIRC you need 26.
Team Owner
Colin those covers look great .
Are the letters also PC or paint? or stickers?
Note in the picture the sealing washers I mentioned would go between the head of the bolts and the curved washers.
Stan,
The letters are painted with engine high temp paint. The letters are a bit of a rip IMO at the price they want.
And yes, dont forget to add the spacing washers between the bolt head, and the convex washers, or it will continue to leak!
Almost Deleted
Kiln, the intake is already painted the same color white. I'm just now getting around to doing the covers. I'll post a pic of the whole thing when I get them installed.
Almost Deleted
Merlin, this is the arctic white high heat engine spray. Its the same stuff I used on my intake.
BTW, thanks for the advice on the washers+HB.
Roger has em
IIRC you need 26.
Roger has em
IIRC you need 26.
Looks good ******.
Almost Deleted
Does this mean you might actually drive the car?
Almost Deleted
Almost Deleted
