Introducing ... my '84 928 S2 rebuild
#76
Thank you all for your great comments...!!!
This is a super place to share experiences and opinions, and get information.. I will try to add some value as well, in stead of just leeching information.
This story is far from over and I will continue soon, just need to get out my camera and make more pictures.. they say so much more
I will strip it down further again... the insulation needs rework.. also because I am looking to upgrade the audio quality...
#77
So when I returned from all the holiday dinner parties, I finally got going...
First thing, remove all that is still in the car, and does not belong there anymore.... before I knew it, the floor was once again filled with parts
Also, time to get out the vacuum cleaner, all the sanding dust is horrible
#80
First problem to tackle, fix the HVAC!!! it is stuck in hot and now that I have access to everything, I can easily check all the wires and functionality...
The repair manual is a big help, turns out the system is wel documented!!
But the problem is easy, I've read about it in a thread here as well... a bad contact in the external temp sensor increases the resistance to infinate, making the HVAC believe it is about -40 C inside....hence, heating to full..
A quick fix, really, but in the meantime all vacuum hoses and actuators have been checked as well...
Since that was all I needed to do at this level, in come the new parts!!
#81
Hi Stefan,
I just discovered your thread and still wondering how have I missed it till now!!!
Great work ongoing, congrats.
Hope we get an opportunity to meet in the new year.
#82
Hi Ralph,
It would be my pleasure!! The 928 herd is pretty thin in our parts...
I am certain we can arrange a meet!
For reference, I am planning to attend the Porsche scene live gathering in Best (NL) 4th of May.
Hope to see you there if not before!!
Grtz
Stefan
Grtz
Stefan
#84
It's been a busy winter, with loads of fun and much less fun challenges. Had to say goodbye to a loved one...never easy but she had a superb life right up till the end, when you think about it, one can only be jealous.
Anyway... loads of excuses to explain why I haven't reached any of the deadlines that I set for myself....but last weekend.....things got rollin again...
Green light from the mrs, a friend to help out on the heavy lifting, and bam... looking more like a car now.
This is the current stance.
All the electrics are operational, just the sunroof gets a significant voltage drop when under load. Anyone has experience with the most likely resistance point? I cannot seem to locate it. Every check I do results in less than 1 Ohm. The only thing left would be changing the wiring, and I would rather not if I have a choice.
