any idea why my windshield has clear "tint" on inside?
Yes, it is illegal where I live. You can't really tell that it is on there.
I was checking into the local rules just now..
In NSW we're note technically allowed to apply *any* film to the windscreen below 10% distance from the top edge. However, the rules allow for manufacturer films, as long as a minimum of 75% of visible light is transmitted.
Clear 6mm glass has a VLT of 89%. The 3m CR90 has a VLT of 86%, and reduces heat gain by 19% (as well as blocking all UV).
Hmm.. so if it were applied to a new windscreen before fitting, and it were even noticed, could we argue that its the Porsche Sekuriflex layer?
I would. Its documented even.
Film..what film..it has no ****ing edge man...Porsche did this!
Shameful Thread Killer
I've learned the right way to remove tint and other films without resorting to the razor blades. Get a Shark handheld steamer, Use a knife or something to make a large X in the tint and start the steamer at the intersection of the X. Get your nail under once section, and keep the steamer on it, then peel it off in one large section, then move on to the next section of the X.
I just did most of my 968 and it came off quite well. A lot easier to clean up than razoring it off and the goo left on the window. With the Shark steamer it takes most of the goo off with the tint.
Cottage Industry Sponsor
This is on your Euro, right? The Euros of that era came with a Sekuraflex windsheild, which had this plastic film laminate on the inside. My Euro had this (since replaced with a "regular" windsheild), and it is easy to damage when you use a blade to remove inspection/registration stickers. It was to prevent glass shattering. US windsheilds have the plastic laminated in between 2 sheets of glass. At least you know it is original.
The trouble was that it required special cleaners, and often turned foggy after a while. IIRC, Porsche discontinued this option before the 1987 model year.
Speed, drop the bomb, what did it cost to have the film applied to the windshield? A little google tells me its around $500 min for most cars.
The 3m stuff last I looked was limited to only so many installers per region, all top dollar. There are some competing products, but 3M looks to be the best, and most likely to pass a HP visual inspection. What I hear is that most people won't even notice the 90% visual transmission stuff.
