928 Forum 1978-1995
Sponsored by: 928 Specialists
Opinions on cam gears
Old 11-12-2012 | 02:13 PM
ROG100's Avatar
ROG100
Basic Sponsor
No you need 928 105 530 04
Our test gears have now completed over 13500 miles on a supercharged car using a Racing Timing Belt with no wear.
Old 11-12-2012 | 02:26 PM
Glenn M's Avatar
Glenn M
Roger,
They look great!
Thank you for helping to keep our cars on the road!
Old 11-12-2012 | 09:24 PM
Opelotus's Avatar
Opelotus
So... what, if any, symptoms arise when the cam gear teeth start to wear???
Old 11-12-2012 | 09:28 PM
Avar928's Avatar
Avar928
Won't they eat into the belt causing the belt to break?
Roger,
Does that mean we'll see them next month? I'm down for a pair ASAP.
Old 11-12-2012 | 09:40 PM
Opelotus's Avatar
Opelotus
I suppose that makes sense, could they cause excessive belt vibration/flutter too?
Old 11-12-2012 | 09:54 PM
jbrob007's Avatar
jbrob007
Originally Posted by Opelotus
Myles, thanks for the info. If the OPs cam gears are bad, mine are TOAST!
Too bad 928MS doesn't make cam gears for 16v engines.
Where can you purchase the OEM porsche ones, I thought they were NLA?
My gears looked similar to these when we did my TB/WP job. I should have replaced them then, but didnt know any better. Replaced the original belt with the Gates Racing Belt and the Porkensioner - minus the air pump. No change in gear wear in 30K miles. I think the stock tensioner & lack of maintenance contributed to excessive belt flapping & was the primary culprit to early gear wear. Still, I'll be replacing my cam gears in 10K miles or so...
Roger, You got any of those fancy golden lookin' cam gears left for an 86.5???
Old 11-12-2012 | 10:01 PM
Speedtoys's Avatar
Speedtoys
The asexual reproduction of dinosaurs.
...you remember what happened _last_ time...
Quick Reply: Opinions on cam gears
