928 Forum 1978-1995
Sponsored by: 928 Specialists
Can anyone name these electrical connectors?
Old 11-07-2012, 06:49 PM
ledee416
ledee416's Avatar
Default Can anyone name these electrical connectors?
all come from inside center console. I assume some are for blower motor and some are for radio, but I simply do not know which is which. a few have power.
Instead of looking at a schematic for hours, I figured I would ask the experts. I will refer to them by numbers so answers will be less confusing
1) this one has heavy gauge wires:
2)
3)
4)
5)
6) all three of the above are out of the same harness:
7)
8) http://i298.photobucket.com/albums/m...1-07172546.jpg
Old 11-07-2012, 07:11 PM
Lizard928
Lizard928's Avatar
rear wiper switch, its male counterpart is sitting on the left in the picture.
#2, and #3 are for the central locking/AC/warning cancel that sits right below the HVAC.
Old 11-07-2012, 07:19 PM
James Bailey
James Bailey's Avatar
Also called acknowledgement panel.......part of what went missing with the gauge "upgrade"
Old 11-07-2012, 07:57 PM
James Bailey
7 should be named Mickey as in mouse.....added on for ?????
Old 11-07-2012, 08:14 PM
ledee416
ledee416's Avatar
I suspected 7 was aftermarkert. no clue what it is attached to.
Old 11-07-2012, 08:16 PM
ledee416
ledee416's Avatar
any idea about 4 and 5? 5 has power to one of the two leads when key is in acc postion
ebay has a dasj indicator with reset switch that has the same 2 lead and same color.. so i guess that is what its for.
Old 11-07-2012, 08:19 PM
ledee416
ledee416's Avatar
so the male counterpart on left should be plugged into the female #1? where would / is the rear wiper switch ?
so none of these connectors are supposed to be hooked up to the blower motor? I believe the blower motor is still in the car, although I am not sure. I assume it is integrated to the black plastic vent box that is in back of center console area.
Old 11-07-2012, 08:22 PM
ledee416
ledee416's Avatar
lol @ upgrade... so true... sunpro makes about the worst gauges known to man. they are mechanical too. so if i acquire one of these panels i should be able to plug those connectors in?
Old 11-07-2012, 08:24 PM
ledee416
ledee416's Avatar
anyone know what the heck #4 is for? in pic 6 you can see that all 3 of those connectors originate from basically the same area of the harness.
Old 11-07-2012, 08:47 PM
ledee416
ledee416's Avatar
blower motor no?
Old 11-08-2012, 03:24 PM
ledee416
ledee416's Avatar
I was able to get a reset button / warning system panel on ebay today. It happens to have the same exact blue and white 2 wire connector match as the one under my console, so I assume it will work.
http://www.ebay.com/itm/400336719349...84.m1497.l2649
it does not however have a power lock button on it, and it appears to only have one other 4 wire connector. I guess it will match up to one of the two in the picture above.
Can anyone else help me identify these other wire/ connectors? I believe I have confirmation that the connector I suspect is to the blower motor is in fact correct.
Old 11-08-2012, 03:34 PM
James Bailey
1980 cars do not have the lock button ....If you need to know what fits what go to 928 Internationals store and look at descriptions and part numbers as they are correct also give you an idea of values.
Old 11-08-2012, 07:47 PM
ledee416
ledee416's Avatar
that works out well then. I believe I bought the correct piece. it came out of an 82. I dont think that connector #1 was correctly identified. Lizard said its male counterpart was in the pic. As it turns out, that green connector is connected to the other half of it... I believe this would mean connector#1 is in fact not for rear wiper... what else could it be? As stated earlier, they are heavy gauge wires. What else coming from that area would use a connector like that with some thick wires? anyone know?
Old 11-08-2012, 08:02 PM
ledee416
ledee416's Avatar
here is the #1 connector that is still unidentified next to what I assume is the fully conected rear wiper connector:
Quick Reply: Can anyone name these electrical connectors?
