928 Forum 1978-1995
Sponsored by: 928 Specialists
FRONT UPPER ARM BUSHING
Old Oct 22, 2012 | 12:16 AM
georges 928S's Avatar
georges 928S
Default FRONT UPPER ARM BUSHING
Hi Guys, need help , iam trying to change the front upper arm bushing,the one close to the rotor, can i do it with out taking of the spring or whats the best way, my car is on jacks waiting. Thanks in advance. Ed.
Old Oct 22, 2012 | 06:47 AM
Landseer's Avatar
Landseer
The upper arm has a pair of replaceable bushings where it bolts to the body.
Those are removed with a small press.
Out near the rotor, there is an upper ball joint w/rubber boot.
Do you mean the ball joint?
A picture could help.
Old Oct 22, 2012 | 11:11 AM
Tom in Austin's Avatar
Tom in Austin
Whatever you're replacing requires the upper arm to come out of the car first.
Old Oct 22, 2012 | 11:13 AM
Glen McCartney's Avatar
Glen McCartney
If he's replacing the ball joint with Carl's ball joint rebuilding kit, it can be done with the A-Arm in the car. Replacing the bushings on the pivot arm does require the arm to be removed.
Old Oct 22, 2012 | 11:56 AM
georges 928S
Default front upper ball joint
Thanks guys, it is the upper ball joint, can that be replaced with the arm in place, becouse the bushings are still in good shape. Thanks Ed.
Old Oct 22, 2012 | 04:32 PM
Glen McCartney
I rebuilt the upper ball joint using Carl's kit, it if for 78-86 model years. Here is link to the instructions he includes with the kit - ftp://928m:928m@12.234.229.133/insta...ointrepair.pdf
Old Oct 22, 2012 | 06:54 PM
Landseer's Avatar
Landseer
Glen, did you need to source a boot other than what Carl supplies?
Its been a few years, but the kit he sold me had unusable boots.
Old Oct 22, 2012 | 07:56 PM
Glen McCartney
Yes, I used the Audi boots, the ones with the kit were not usable.
Old Nov 8, 2012 | 06:57 PM
georges 928S
Default upper arm ball joints
Hi Landser, yes i did use the boots from carl the only problem i had was with instaling the wavy springs that holds the boot to the arm. by the way Landser, do youk now what the torque is to tightin the bolt. Thanks Ed.
Old Nov 8, 2012 | 07:26 PM
Landseer's Avatar
Landseer
65 Nm
