928 Forum 1978-1995
Sponsored by: 928 Specialists
What the hell is this behind the balancer?
Old Oct 14, 2012 | 07:47 PM
Charley B's Avatar
Charley B
Default What the hell is this behind the balancer?
The only thing I can think of is the little belt guide roller that sits below the crank at about the 8PM position to the harmonic balancer. This is sitting at the 5PM position. It rolls smoothly and doesn't seem to touch anything.
Could that assembly have been installed backwards!!!! If it was, can I just leave it this way? I don't think it ever touches the belt when installed properly anyway.
P.S. I disconnected the sending unit to get a better picture.
File Type: jpg
File Type: jpg
File Type: jpg
Old Oct 14, 2012 | 07:52 PM
SeanR's Avatar
SeanR
Depending on the year, there are either zero, one or two rollers. You've got a two roller car and a slight mess.
Old Oct 14, 2012 | 07:55 PM
Charley B's Avatar
Charley B
Sorry. '88 S4. So it's a two roller assembly and belongs there?
Old Oct 14, 2012 | 08:09 PM
SeanR's Avatar
SeanR
Yep, chances are they are sized or so full of dirt they wont spin. Just clean them up real good and they should be ok.
Old Oct 14, 2012 | 08:19 PM
Charley B's Avatar
Charley B
Thanks Sean.
Old Oct 14, 2012 | 08:31 PM
Hilton's Avatar
Hilton
Buy two 6201RS bearings (its a standard size and they're cheap).
When you remove the arm which the rollers are on (two small circlips), remove the rollers (two slightly bigger circlips and if stuck hard, a small puller). Then press the bearings out with a socket in a vise and replace them, after inspecting the roller surface for wear (driver's side will likely have none - so swap their sides).
Old Oct 14, 2012 | 09:41 PM
the flyin' scotsman's Avatar
the flyin' scotsman
The rollers hold the tbelt to the crank........sometimes.
Much debate sometime ago re effectiveness...........I took mine off and left them in the parts bin when I converted to the Porkesioner..........years and 1000s kms ago
btw........you need a OPG
Old Oct 14, 2012 | 11:09 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
Porsche put them in there because they needed to add more weight and make the engine more complex?
Old Oct 14, 2012 | 11:13 PM
James Bailey's Avatar
James Bailey
You can get replacement bearings for little money.....originally it was a plastic slide like 911s use then one roller then two....But like Greg said it was just some engineer building job security and adding weight and complexity
Old Oct 15, 2012 | 06:22 AM
Leon Speed's Avatar
Leon Speed
Since when does the roller sit on the left side of the crank? Ok I see two rollers, one on each side?
Old Oct 15, 2012 | 06:43 AM
Vilhuer's Avatar
Vilhuer
Two on some MY S4's. Early S4 used single roller. Second version used two and final version one larger roller again. Changes were done in middle of MY in '87 and '90 MY starting fron certain engine numbers. Plastic cover behind roller was also changed at same time.
Old Oct 15, 2012 | 09:54 AM
GlenL's Avatar
GlenL
We can't just sit there looking pretty.
Old Oct 15, 2012 | 06:26 PM
dprantl's Avatar
dprantl
Those idlers are there because they are a bandaid for the silly characteristics of the stock tensioner. The belt can flap so much with it in certain circumstances (while it is properly adjusted to the factory tension setting) that the engineers were probably crapping their pants trying to figure out a way to fix it without completely redesigning the system. That is the only explanation I can envision, because I cannot fathom a smart engineer inserting a smooth idler pulley where the TOOTHED portions of the belt can contact it.
You will not find such a tensioner system in any car designed in the last 15 years. The design is adequate at best.
Dan
'91 928GT S/C 475hp/460lb.ft
Old Oct 15, 2012 | 07:57 PM
Whitesands's Avatar
Whitesands
+1
