928 Forum 1978-1995
Sponsored by: 928 Specialists
Help ! Sudden No Auto Gear Shift
Old 03-28-2013, 04:46 PM
  #256
Kevin in Atlanta
Kevin in Atlanta's Avatar
Pretty straight forward - I've dropped it with and without the axles attached. Me, I would drop the whole subframe as a single assembly after pulling the calipers and hanging them. Also, the emergency cable has to be disconnected and the speed sensor and what ever is attached to the tranny. Is this in your garage or on a lift?
Old 03-28-2013, 04:52 PM
  #257
MainePorsche
MainePorsche's Avatar
In my garage on Liftbars.
I was thinking without the axles attached.
Old 03-28-2013, 05:00 PM
  #258
Kevin in Atlanta
Ask Dean_fuller what he would do - he has done this a few times recently. And without the benefit of the liftbars. :-0
Old 03-28-2013, 05:05 PM
  #259
MainePorsche
Originally Posted by BRB-83-911SC
Be sure to mark the location of crossmember to body and eccentrics to body. You can use a paint marker on cleaned surfaces. Then realign to marks upon re-install.
Make sure transmission is secured to the jack when lowering/raising - it will tend to roll off. A transmission jack with a tilt platform makes this job a lot easier.
Some good write-ups should return from a search. Good luck.
Thanks Brian.
Yep, have two different colored paint pens.
Don't have a specific trans jack, but am thinking of fabbing something for stability.
Would you know off hand the chain length for the strap to hold trans up ? Might be hard to get a good measure till I'm there.
Old 03-28-2013, 05:57 PM
  #260
BRB-83-911SC
BRB-83-911SC's Avatar
Originally Posted by MainePorsche
Thanks Brian.
We (should give credit to Dave C.) used a ratchet strap to suspend the transmission, hooked to the sway bar, while dropping the entire rear suspension/subframe. You could use multiple straps for redundancy.
We disconnected the half shafts from the transmission, and left them attached to the wheel hub, and just rolled the whole assembly out of the way. Be sure to support the half shafts.
Old 03-28-2013, 06:10 PM
  #261
MainePorsche
Ratchet straps.... I must have been asleep at the wheel.
Old 03-28-2013, 06:12 PM
  #262
Kevin in Atlanta
I have some ratchet straps if you want to borrow them.
Old 03-28-2013, 06:22 PM
  #263
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,322 Likes on 500 Posts
Here's Dean thread on his transmission removal.
Very useful I think.
https://rennlist.com/forums/928-foru...-you-tube.html
Old 03-29-2013, 02:44 AM
  #264
MainePorsche
Shark,
Thanks, I'm all set with them.
Old 03-29-2013, 02:48 AM
  #265
MainePorsche
Betrand,
Merci beaucoup. Dean's video is very good.
Old 03-29-2013, 08:11 AM
  #266
Bertrand Daoust
Betrand,
Bienvenue mon ami.
Yes, a very good one for anybody doing this job I think.
Thanks Dean.
Do you plan to do other things while there?
Like the rear seal, TT bearings, torque converter seal, etc...
I know that the trans swap is quite a big job but that would be a great time to do many things.
Old 03-29-2013, 09:17 AM
  #267
MainePorsche
Bienvenue mon ami.
Thanks Dean.
Bertrand,
I would have liked to have done the TT bearings, but I am at the tail end of a catastrophic matter which has caused much fiscal pain. These bearings will have to wait. I was fortunate enough to be able to get the transmission. It is one of Greg's 'new' ones that he found in a warehouse in Germany. This new unit is from the torque tube to the rear axles so I imagine the TC seal will be good to go. As I get the experience of dropping the rear end now, I was thinking of Constantine's Super Bearings when I'm completely on my feet, and putting in Bilsteins all around. So far no signs of bearing dysfunction, but I am cognizant of them.
Thanks again,
Craig
Old 03-29-2013, 12:14 PM
  #268
michael j wright
michael j wright's Avatar
Are you going to give the old trans to Greg so he can do a diagnosis on it? Would be very interested in what he could find out.
Old 03-29-2013, 12:53 PM
  #269
MainePorsche
Yes I am.
I'm very curious as to the cause. If it were the shift regulator valve in the valve body giving me these symptoms, then why the low Operating Pressure ? If it were a damaged/then blown something-or-other in the transmission itself giving the symptoms and the low Operating Pressure, then why no warnings heard/felt during the failure of these moving parts ?
Well, I think the best thing I could've done for the long term preservation of the car is to put in a new 722 MB transmission while the rare find was still available.
Old 03-29-2013, 04:31 PM
  #270
Bertrand Daoust
Bertrand,
Thanks again,
Craig
I understand.
And yes, it is always easier the second time too.
Quite a nice transmission you found there.
Brand new! Wow.
Very curious too about the cause of failure of the other trans.
Good luck and let us know how it goes.
Quick Reply: Help ! Sudden No Auto Gear Shift
