What are these things under the passenger's side of the dash?
I was getting an intermittent ABS light, so I went under the dash on the passenger's side to check connections. Fixed the ABS issue, and reconnected the glove box light and the vacuum line to the computer while I was down there, but couldn't find where the connector in the first couple pics should go. Also found the black box (bulb controlling device) in the third pic just sitting on the floor behind the rat's nest. So...
1) What does that connector go to (and where)?
2) Where does the black box bolt on?
Thanks in advance,
Matt
Thanks in advance,
Matt
Last edited by Payload; 10-08-2012 at 11:03 PM. Reason: referred to wrong pic in text
Team Owner
its an unused connector,
Not exactly sure what it was used for possibly a trigger wire for the passenger ejection seat.
place it out of the way
Looking at the passenger parcel tray you will find an area on far right side of the tray (as sitting the seat }where the lamp controller bolts to the tray
Inventor
IIRC, the single terminal is +12V for rear A/C controls.
Ejector seat would explain why the things in the back are called "emergency seats". ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
No rear A/C in this car so I'll just strap that one down a little better.
Thanks for the ID and position info on the controller - time to go find some bolts.
-Matt
-Matt
